Shiva-X2 "Easy Button Mini"
  • BeerParty
    • 475
    First, a little background...
    In another thread, Neo Dan complained that there had been no new designs lately. He has helped quite a few builders, so his complaint shouldn't be taken lightly. So, even though it is not quite ready yet, I'm posting up my design for review and forum use. I was planning to build this and post a build thread, then my circumstances took a change for the worse and I have had to put it off for a while. I was going to wait, but Neo Dan's point was well founded. So, here it is.
    Now, on to the show...
    This is a slot port design for the Shiva-X2 based on Neo Dan's Easy Button Max Design for the Maelstrom-18. It is a 3.5 cu ft enclosure, slot ported, tuned to 20Hz (this is one of the designs in the Shiva-X2's application notes). It looks like a miniature Easy Button Max (that's deliberate, Dan! ;x( ), thus the name.
    The one unique thing about this design - I planned it around handy panels, so people that don't have a vehicle that can carry a 4' x 8' sheet of plywood could build the sub with the 2' x 4' handy panels. The whole sub can be built with 5 of these panels.
    Here is a Google sketch-up image of the box:
    Click image for larger version  Name:	Shiva-X2 3.5cuft Easy Button Box image.jpg Views:	1619 Size:	66.9 KB ID:	870366
    The box is 21" high, 21" wide, and 26.25" deep. It is designed with 3/4" panels and a double front baffle.
    If anyone is interested, I have a cut sheet for the box.
    My Statement Monitors Build
    My AviaTrix Build
  • Bent
    • Sep 2003
    • 1570
    I'm interested in the cut sheet.
    • Ezcl
      • Jul 2008
      • 61
      Looking good.
      How do you get that semi-transparent look in SketchUp? I could never figure that out.
      "Measure twice, then measure again before even thinking about plugging the saw in."
        I don't think having one's legs build into the box is going to beneficial ....... :rofl:
        • numberoneoppa
          • 535
          Oh, come on Thomas, don't you just *love* the shoes, though?
          -Josh
            • 5204
            I'm interested in seeing the FR model.
            • BeerParty
              • 475
              Cut sheet
              Below is the cut sheet. The image isn't the greatest, I made it in MS Word ops: . Once I figure out how to make a better image out of it I will scan it in.
Name:	Shiva-X2 Cutsheet.jpg
              My AviaTrix Build
              • BeerParty
                • 475
                In SketchUp, under the View Menu, select 'Face Style', one of the selections is 'X-Ray'. If you select that, you will get the semi-transparent look.
                My AviaTrix Build
                • hifijeepster
                  • May 2009
                  • 9
                  Using the program "cutlist" works wonders in figuring out how you should cut your wood. Simple and easy to use
                  • BeerParty
                    • 475
                    This design is based on the 'Medium Ported (3.5 cubic feet) 44oz. Poly-fill 20Hz tune' design in the Exodus Shiva-X2 Application Notes (the PDF is available from DIYcable.com ). Page 11 has the design description and the SPL graphs.
                    My AviaTrix Build
                    • BeerParty
                      • 475
                      Here are a couple of shots of the internal bracing, with measurements. It should be enough info to see what needs to be done.
                      A 3/4 view with the box outline, so you can see the interior:
                      A side shot with measurements:
                      My AviaTrix Build
                        • 5204
                        +1
                        • JonP
                          • 692
                          Hey, don't we all love that "pants leg flapping" bass?? :B
                          Cool build, and great documentation with the Sketchup and cutlist shots.
                          • evilskillit
                            • 468
                            Looks pretty sharp, I thought the Mal Easy Button was awesome. This, tho smaller in size is equal in awesomeness.
                            • BeerParty
                              • 475
                              OK, OK, point taken... :thud:
                              My AviaTrix Build
                              • BeerParty
                                • 475
                                Thanks!
                                My AviaTrix Build
                                  • 5204
                                  Those look great. I bet you use it on all your projects now.
                                  • Silver1omo
                                    • Sep 2010
                                    • 430
                                    This looks very interesting. I made a couple of quick calculations (probably wrong):
                                    ~118L tuned around 18Hz
                                    WinISD says 82db at 20Hz
                                    What would you use to power it?
                                    Ivan.
                                    My Statement monitors
                                    • BeerParty
                                      • 475
                                      I have not thought that far ahead. The Shiva-X2 should not need a lot of power, you would only need about 500W wired (for a 4 ohm load). In fact, if you were willing to give up a little space inside the cabinet a 500W plate amp could be built right into the side.
                                      My AviaTrix Build
