Horn questions below tuning frequency
  • mackintire
    • Jan 2009
    • 186
    Just a quick question, Is the behavior of a folded horn (in this case the tuba THT) the same as a sealed box? As I understood it the THT is +3db compared to a sealed box with equal volume at 18hz (not accounting for room gain).
    There appears to be a group over at AVS who are using the RS390RF in the THT specifically so they are make the unit more usable below the tuning frequency.
    Many of these guys claim they can eq the units pretty flat to 15hz using this driver instead of the Dayton DVC normally recommended.
    They also are claiming that the DVC runs out of headroom quicker when driven hard past the tuning point.
    Does this sound reasonable or true to you?
  • 1Michael
    • 295
    Not really. I am using the RS390HF in my THT and below 20Hz it drops off like a rock. I do not know how anyone is getting any real output below that except for maybe room gain. I don't consider the THT a Sub because of this drop off at 20. I much prefer my sonosub for movies but I prefer the THT for music. I don't know about the DVC because I have not used it...
    Michael
    Chesapeake Va.
    • mackintire
      • Jan 2009
      • 186
      I dug farther into this topic last night. In "a room" the THT falls rapidly -10db by 17hz.
      It seems some are boosting +8db at 18hz and placing a high pass at 15hz
      This seems to achieve what appears as -3db just over 15hz. The only problem is the horn is magnifying the harmonics below the knee. So the debate is whether or not they are getting their desired result. The 5th harmonic is pretty big at that point and the third harmonic is not huge but its there non the less.
        Yeah, the one I built with a DVC didn't have audible output below 20hz. I never had time to measure it, but I never heard it where it was supposed to be.
        • A9X
          • Jan 2007
          • 107
          Below Fc the driver is going to behave the same as it would baffle mounted in a box the same volume as the rear chamber in the horn.
            Exploring Common DIY Terminology - Dual Voice Coil (DVC)
            by technodanvan
            A dual voice coil (DVC) design is a configuration commonly used in loudspeaker drivers, particularly subwoofers. It involves a speaker driver with two separate voice coils wound on a shared former (the cylindrical structure that holds the voice coils), each connected to its own set of terminals. Each voice coil is wound with its own wire, and they are physically separated but located on the same former. The former is connected to the speaker cone, which moves in
            18 July 2023, 13:54 Tuesday
          • stgdz
            First REW sweep with my THT
            by stgdz
            So I finally got around to getting a radio shack mic and was able to run REW with it last night on my THT
            A couple of troughs in their but its pretty decent. Any hints on improving the troughs?...
            20 February 2010, 11:17 Saturday
          • swithey
            SWithey DIY Dual 15” Subs – Down to 15Hz
            by swithey
            Intro
            I’m a long time AVSer and have recently discovered HTGuide and the “Mission Possible DIY” Thread. I’m in the process of building out my HT and wanted to have some serious bass in the room. My small to medium sized room is 14.5’ wide x 19.5’ long x 8’ vaulted to 10’ ceilings...
            31 May 2006, 00:15 Wednesday
            Exploring Common DIY Terminology - Horn
            by technodanvan
            Horn
            A horn refers to a type of acoustic device used to improve the efficiency and directivity of sound reproduction. It is designed to efficiently couple the sound energy from a loudspeaker driver and effectively project it into the listening space. A horn can enhance the overall performance of a loudspeaker system by increasing sensitivity, controlling dispersion, and extending the low-frequency response. The primary function of a horn is to transform the relatively small diaphragm...
            18 July 2023, 20:11 Tuesday
          • tktran
            Peerless XXLS 12" DVC (830837)- replacement for PE Dayton 12" DVC 295-185?
            by tktran
            I've been modelling the new XXLS series to see which model would be a suitable replacement for the Dayton Audio 12" DVC (PE #295-185). It will be used in my current 1.5cu ft sealed cabinet and 250W (4ohm) plate amp with boost (v. similar to PE #300-796, boost settings are...
            13 August 2005, 03:47 Saturday
