This is only partly audio related, but I really respect all of the people here and I want to hear what you all think. I need an oscilloscope... mostly for school, but also to use on audio projects. I also need a logic analyzer, I am currently planning on specializing in embedded design. The problem is that I dont really know exactly what I need. Here are some options I am looking at:
Rigol DS1102D : 100MHz MSO. This one has an integrated logic analyser. Pros: good size buffer, relatively high bandwidth, logic and analog time synced! Cons: extreme limit of my price range, only 8-bit vertical resolution.
Rigol DS1052D : Same as above but only 50MHz, so add slightly low bandwidth to the cons.
Bitscope 325 : This one also has the mixed signal as well, but I just have a really bad feeling about a USB oscilloscope... I don't know why. The specs all look ok (except this one says 8bit vert resolution with only 6.5-7.8 effective, whatever that means), I just don't know if it is an effective tool or not.
Analog Scope + 8-bit logic analyser: What I mean here is something like an old Tek 2400 series, maybe 200-300 MHz, perhaps even 4 channel. Then a separate logic analyser, something like a Saleae Logic . In this case I think the scope and analyser would both be better than the equivalent above, but not synced in time.
So, if I go with the Rigol will I need the 100MHz? Or do you think one of the other options better in the long run?
I appreciate any help and comments, I know there are a lot of EEs here.
Chad Huard
Chad Huard
Basically it means the INL/DNL of their ADC sucks, and even though it spits out an 8 bit number there's inaccuracy enough that you really only get 6.5-7.8 effective bits (lower as sample speeds go up usually). Read up on INL, DNL, and ENOB, it's good stuff to know, esp for embedded systems design.
