Sumo Delilah Info for those curious
    • 16202
    Several people have PM'd me about the Sumo Delilah II, interested perhaps in why I have one, what it can do, any documentation about it. I've had it for some time, bought it from a business acquaintance back in about 2001. It's a simple two way crossover setup for adding woofers to existing systems that may or may not be full range. Originally it was designed to work with the Sumo Samson subwoofer, though keep in mind the timeframe in the 80's and that long throw subs as we know now didn't exist. Sumo was founded by James Bongiorno, the founder of GAS, designer of AMPZILLA, and many other amplifiers at SAE, and even the Dynaco ST400. The main product focus of Sumo was amplifiers and preamps, though they did some speakers, including the Opus one, which used full conjugate networks (kind of like the Ardent) and presented a mostly resistive load to the amplifier.
    I've scanned the manual (last night), and here's a link for a PDF, under 6 MB.
    Sumo Delilah II Manual.pdf
    The nice thing about this unit is the flexible crossover tuning possible with low order slopes, and the point that the high pass is a strictly class A non feedback buffer- about as transparent as you might want, aside from upgrading the caps. (on my list of to-do's).
    Will post pictures of front and back panel soon. Nothing on the Holonet worth warm spit.
    Click image for larger version  Name:	Sumo Delilah II-1127.jpg Views:	3489 Size:	71.0 KB ID:	870259
    Click image for larger version  Name:	Sumo Delilah II-1128.jpg Views:	2933 Size:	95.6 KB ID:	870260
    • 16202
    Pictures added.
      Sort of Compact Line Array
      OK guys, I agree to quit hijacking threads like the monopole vs dipole discussion and present my nutball ideas in their own separate playground...
      This thread will document my design efforts and construction for a "compact" (sort of) line array (at some frequencies)...
      11 December 2002, 16:22 Wednesday
      DIY Northern CA
      It was a warm, busy day in Rocklin California yesterday, for the DIY Speaker meet which Mark K. hosted at his home. We had a pretty good sized turn-out, over 30 attendees altogether, with quite a few bringing projects, some quite sizable, to share with the other attendees. Mark also had his garage open...
      01 June 2003, 12:22 Sunday
      How about a monster baby sub?
      Well, you know, I really like the sound of the Aerial Stryke, but my Gawd, that puppy is big and heavy. It's made me think a lot about how to get a "monster" sub in a smaller box.
      So, yesterday, in my copius spare time during lunch, I got out my copy of Unibox spreadsheet,...
      20 September 2001, 09:14 Thursday
    • Tito
      Problemas con la pantalla OSD del RSP-1098
      by Tito
      Hola a todos, tengo problema con la pantalla del 1098, no se ve nada, si prende pero no saca ningún menú, y si se ve en la pantalla que tengo conectada por medio de los 3 cables Component.
      Antes de esto, al presionar menú, en la pantalla OSD se mostraba el menú pero como distorsionado o barrido,...
      09 June 2015, 11:44 Tuesday
    • meltdown
      Paradigm Speaker Options for my RB-1090 + RMB-1075
      by meltdown
      Well, I started off bi amping off of my Marantz with a couple carver M500"s and pushed the noise through a couple of Monitor 9 Paradigms and used the internal amps of the Marantz to power the center and surrounds. It was an improvment from before. The shock wave would loosen the puddy in the windows...
      16 August 2006, 02:43 Wednesday
