Hello All,
I'm working up to commit to build a pair of Jim's Statement speakers. Jim thanks for the email reply about which version to build. I've decided I would build the Statements rather than the mini's. I want to start by thanking Jim, Curt and all who contributed to the well documented designs and generously made them available to use. I will cut to the chase and post some questions below for all to comment on regarding some of the documented features and the possible impact of deviating. However, I want to remain as close to the documented design as I can, you can't argue with success.
1) I want to consider moving the whole array up ~3" and lowering the base by the same amount and porting through either the front or rear. This would leave about 2" distance between the top edge of the woofer and the outside top of the cabinet. Effectively the cabinet will be 3" shorter now and the tweeter is still at 38" from the floor. Any concerns about cabinet resonance or TL effect, refraction or something?
2) Where in the cabinet are the x-over networks typically located? If I forego #1 above I could place it in the base.
3) What internal wiring are the enthusiasts using these days?
4) Upon completion of the speakers should I expect a need to do some voicing or tweaking of the x-overs, L-pads, etc.?
Thanks to everyone in advance for all your inputs,
John...
John...
