I have a question, - what is a reasonable power requirement for the power amplifier to drive an RD-75 driver operating from 500 Hz and up, in an dipole set-up? In other words how many Watts would be sufficient to achieve realistic SPL? Right now I am using about 150 Watt (6 Ohm) power amp and it is fine, but I am wondering if I can get away with much less.
Reason being is that I am in the process of assembling my ExtremA (http://www.hardwareanalysis.com/cont...diy-amplifier/ ) power amp. This is a Class A amplifier, and as such its heat-sinking requirement are considerable. To build a stereo 100 Watt Class A power amp is like building a monster that will end up weighing about 70 pounds it might be more.
So I am thinking about lowering the power to let’s say 50-60 Watts (6 Ohm). And here I am facing 2 choices that I need help deciding on.
Choice One: Build a Class A 60 Watt amp. But it may not be sufficient to drive my RD-75 section of my 3-way dipole speaker (http://home.comcast.net/~thomasw_2/VictorFront.jpg ) to realistic (read HIGH) SPL levels.
Choice Two: Build a 100 Watt amp that will operate in Class A only up to 30-35 Watts and if more power is needed the amp will depart Class A operation and will switch into Class B.
So what is the best course of action here?
Thanks in advance,
Victor
Thanks in advance,
Victor
