That is also a fine plan Steve.
I would think you may have some challages trying to get them close enough the speaker cut out, but one could also tap those holes off center to the nut. If I was going to attempt this I would probably choose aluminum. In case one of the nuts gets nicked while trying to bevel the inside of the speaker cut out. My job requires me to use alot of aluminum and I use a standard wood router & bit to put chamfers and round overs on aluminum pieces, so I know standard carbide cutters can easily handle cutting the aluminum.
Honestly, it sounds like a lot of work.
Good luck - let us know.
