Thru extensive review of projects and assoc. pic's here within, I've noticed so many of ya'll don't appear to screw anything together. It looks like everything is glued only.
Are you guys just gluing or are you also using screws from the inner side?
I'm just wondering because I was going to screw and glue, under the assumption that you would cover up countersunk screws with puddy and laminate anyway. Am I overlooking something?
