Scanspeak D2904 980000 crossover / breakup
  • charliemouse
    • Jun 2007
    • 25
    I'm trying a scanspeak d2904/980000 for a project and wondered if any users with experience could advise on taming breakup etc. I've found various mentions of the speaker but can't seem to find answer anywhere.
    1. Does the large (above 20KHz) breakup need taming? I guess Jon's use in Avro has two filters, but both aimed at 500Hz resonance. Also - noting the two filters: is strong inhibition of resonance paramount compared to other speakers?
    2. Has this speaker changed in its life? Jon's picture shows no wavguide like here, and that appears to be aluminium coloured not black like the version here.
    3. What is the waveguide for? Off axis measurements? What would happen if I remove it?
    4. I find the response (aside from 'actual' dB) is 5 dB less than Seas H1322 at all distances, though it should be the same within a few dB and is hugely less than fountek neoCD3. I'm not all that experienced: this could be normal, but I wonder if anyone knows whether this is normal? It might be to do with unusual waveguide/directionality of the other two tweeter I have.
    Thanks hugely!
  • augerpro
    • 1871
    1) Only if you think you can hear it. As far as taming the resonance at Fs, I found it impossible to get the tweeter to adhere to LR4 slope without a trap.
    2)I believe Jon removed the phase shield. Don't know about the non-black version. Maybe and early version? Or a short lived version that didn't sell well?
    3)They are used on metal dome tweeters to shape the upper FR I believe. I think they smooth the response and push the resonance up, but they can cause some energy storage in the top octave. I don't know how it would effect the sound if you removed it, check teh Arvo Part thread where Jon compare's the difference.
    4) It's not a very efficient tweeter, although 5dB sounds like a bigger difference then it should be.
    ~Brandon 8O
    DriverVault
    Soma Sonus
    • TacoD
      • 1080
      You don't need to suppress the dome breakup of the 9800. The notch @ 500 Hz is to attenuate the resonance (Fres), the x-over filter also works better. The latest 9800 tweeters have a black anodized dome and all have a waveguide (but Jon removes it). Early versions are not treated (this tweeter is an old design). IIRC removing the waveguide improves the off-axis response. The sensitivity of this tweeter is not great, modern tweeters (like the Seas) have more efficient motors. Comparing with a ribbon tweeter is not fair , due to the increased radiating surface and huge magnets you get higher SPL.
      • capslock
        Purifi white paper shows that a series notch can decrease breakup distortion
        by capslock
        Quite interesting after cursory reading. They have an alu cone with a 5 kHz breakup and decrease distortion by adding a series notch that has about 45 Ohms impedance at 1650 Hz. Seems this higher driver impedance decreases motor distortion, so it is not at all about the mode coupling into the motor...
        03 April 2022, 10:53 Sunday
      • charliemouse
        notch filter depth / W22 breakup
        by charliemouse
        Just wondering if anyone can suggest how deep to make a parallel notch filter (i.e. L,C&R in parallel with each other, in series between crossover and driver driver).
        As I understand it, the L&C of an LCR effects the frequencies targeted, and the 'R' of an LCR effects...
        03 April 2008, 18:02 Thursday
        More waveguide madness
        by Dennis H
        As noted on the Mad board, Earl Geddes has designed a commercial speaker with a 15"
        woofer and a 15" waveguide tweeter crossed at 900Hz. He has a whitepaper on the page
        that talks about a "Refractive Sound Plug" to eliminate HOM (high order modes), i.e.
        reflection...
        10 October 2005, 14:10 Monday
        Poobahs - basket resonance?
        by Dennis H
        I was perusing SL's site and he has a new article on mounting drivers.
        http://linkwitzlab.com/frontiers_2.htm#N
        This caught my eye:
        "The basket-magnet resonance.... Often the resonance can be seen as a small bump in the driver's impedance curve in the...
        29 November 2004, 22:52 Monday
      • Patrick Bateman
        How to Use a Waveguide with a Woofer
        by Patrick Bateman
        In the past few years, there has been a lot of interest in loading tweeters in waveguides. More articles have been published on this lately than ever. But what about midranges? How do you use a midrange in a waveguide?
        In this thread I will examine the advantages and disadvantages of waveguide...
        03 November 2006, 10:29 Friday
