After months of snooping around this forum as well as a few others and researching a set of speakers to build I have settled on a set of Natalie P floorstanders as layed out in the mission accomplished thread on this forum. This is my first speaker build and first serious attempt at carpentry :T (with the exception of a sealed subwoofer box for my car)
They will be ~60L gross and ported to 28hz as recommended in the Nat P thread. I will be making them out of 3/4" birch ply and finish will either be some sort of red or other dark stain or a black textured paint coat (possibly truck bed liner, not decided yet ) They will eventually be powered with a crown xls 402 pro amplifier
I have started cutting the needed pieces although I have managed to run out of wood I have the front baffles, sides, backs, braces, tops and bottoms cut although I intend to make a double-thick front baffle and there is not enough wood left, so I will need to swing by home depot tomorrow and get a small sheet of wood. I never bothered adding up the area of this thing and I just assumed 1 4'x8' sheet would be enough, oops ops:
My not so interesting pile of wood:
Also, I am cutting these things with a circular saw and the saw blade I bought is already dull. The last several cuts were very slow and smelled like wood burning. 8O I suppose I will pick up another one of those as well (It was a cheap $5 steel blade as I could not find any carbide blades with the number of teeth needed for cutting plywood) As if that wasn't ghetto enough I am doing my cutting on a plastic table on my back porch :rofl: (I currently live in an apartment/townhouse with no garage) The edges are kind of sad although they will be rounded over anyways with a router and so it should not matter too much.
Will wood glue alone be fine for holding these together? I have contemplated using dowels or finishing nails although I have not noticed anyone else using such things in their designs and so I am not sure if it is even necessary. If anyone has any advice I am all ears, and I'm sure I will be asking for help down the road. I am trying to document everything as I go along so hopefully this will be interesting to someone.
