I have Polk RT1000P mains and a CS245 center which is too small really with only 5.5 drivers. I want a much larger center soundstage. I should have the CS1000P center which is 4 x 6.5 drivers.
The CS1000 is tough to find and fairly old now. It is also a little deeper then i would like. I also looked at the CS350 with its 4 x 4.5 drivers. i think i want something more like that, wider with more drivers, but still an old used speaker.
So... would it be possible to expand my center with a new enclosure and 2 more 5.5 drivers and either modify or replace or add to my existing crossover in my CS245? i have found the drivers already and am looking for advice if this is feasable. I would basically end up with a CS350 with 1 inch larger drivers. my goal would be to have the similiar 10 inch depth and it can be any width needed. Also would my denon 887 model 100watts be enough power?
CS245 doesnt seem to be on there but the 245i is basically the same thing.
I am new to this forum but after much reading, you guys are just amazing and can probably design this with your eyes closed
thanks
thanks
