Damping Materials
  • Lindahl
    • 60
    Damping Materials
    I'm building a sealed ~3.5 cuft TC-3000 subwoofer (well two.. and some speakers ). Will I need to line the subwoofer boxes with any damping materials? I've heard they're mainly for ported systems, and I should just use a little polyfill and EQ to adjust to my Q tastes?
    Sealed subs are stuffed. The rate is .05-1.5 lbs/cu ft.
    Fiberglass is the best choice for this task, but you can use polyfill
    Establish the initial amount you want to use then fine tune it.
    Use a CD/DVD you're familiar with that has well recorded bass. Play a section of the disc and listen for any nuances or cues that will be helpful. Real musical instrument transients (not synthesized) are the most revealing. So things like the attack of a kick drum, pluck of a bass guitar string, etc., note are good indicators.
    Next you're going to add damping material and replay your reference cut. (those with smaller boxes add 4oz, if the box is large add 8 oz.) If the additional material results in tighter bass with better definition and detail, you're on the right track. Continue this process (adding and listening), until the last amount added has no impact other than to lower the overall output level. At this point remove the last amount of damping added and you're done.
    • Lindahl
      • 60
      That's the problem, I'm not sure if I can reach some of the volume after the box is built.
      The box is braced with a central brace, running the height and width of the box. There are two horizontal braces behind that (in the back of the sub), running the width and depth of the box.
      Here's a diagram:
      Code:
      X      |   2   |
      XX     +-------+
      XXX 1  |   3   |
      XX     +-------+
      X      |   4   |
      The X's are the driver. I've numbered all the volumes that are seperated by braces (but are open to one another through cutouts). I'll have no problem lining volume 1, after the box is built. But volumes 2, 3 and 4 will be difficult to reach and I'm not sure how much of it I can line. Do I want to line them now while the box is open? Or should I just not worry about it?
      Great instructions, by the way. Thanks.
        Line the inaccessable areas before closing up the box. Add more if needed by pushing it in with a stick
        • wildfire99
          Subwoofer Box Materials/Construction
          by wildfire99
          I just finished up a pair of 18" Avalanche subs in two 24" cubes. Due to a total brain fart, I calculated the interior volume based on the external dimensions (doh).
          Anyway, they're measuring with a rather pretty 10db hump from 40hz up, from the box, or room, or both. I may...
          06 August 2005, 03:55 Saturday
        • JonP
          Box materials, construction tecniques
          by JonP
          Hi all...
          So, as I near the time I need to really get going on a set of wedding present speakers, I'm pondering construction materials.
          I'm probably going to build a set of Modula MT's, or Nat P's.
          After recently re-reading Jon's article on the original...
          28 November 2006, 04:00 Tuesday
          Testing subwoofer tuning and playing with damping
          by ThomasW
          To do this method one needs.....
          1) a power amp, or receiver
          2) a DMM (preferably a TrueRMS unit)
          3) a method of generating low frequency sine waves (tone generators are easiest)
          4) a approx 100watt, 20 ohm power resistor (there's latitude with this value, so just...
          16 January 2006, 17:19 Monday
        • pjcruzn
          damping materials
          by pjcruzn
          Okay subwoofer enthusiasts, what is your opinions on internal damping materials for speaker cabinets? What do you use? "Egg crate" or wedge foam on the interior walls? Acousta-stuff type fillings in the open air space and how much? Both?? Does it effect the long sound waves of the low freqeuncies...
          12 March 2005, 00:43 Saturday
        • fbov
          Tuning effect of damping material volume
          by fbov
          I'm making a pair of ~70l NatP tower enclosures, and by chance have a large amount of Whispermat-like accoustic foam, enough to cover most of the interior of these enclosures. I understand that would be overkill, but it leads me to ask if I should subtract the volume of absorbent added when calculating...
          30 November 2008, 21:39 Sunday
