DCX2496, 6 channel R/C volume control kit and...
    • 10931
    More goodies for the DCX2496
  • chasw98
    • 1360
    Didi you see this page? http://www.selectronic.fr/upload/pro...ogue/15-08.pdf. See anything familiar being used?
    Chuck
      • 10931
      Chuck
      The French language or BB op-amps?..... :B
      • Habs4life
        • 85
        I want one of those 6ch remote jobbies.
          • 3791
          Downstream volume control is the Mercedes of SQ using the DCX but I think you can get 90% of the way there just doing like the pro guys have always done and optimizing your gain structure. That means you set the gains of all the components (preamp, EQ, amp, speakers) so they all clip at about the same time as you increase the signal level. For the DCX that means you need adjustable gain on the amps to set the levels. It could be the built-in gain knobs on a pro amp or a pot or fixed resistors between the DCX and the amp.
          • AJINFLA
            • 680
            8 ch volume if you need 2 extra for your 4 ways, subs, etc. for $500
            Welcome to Emotiva Audio Corporation. Home Audio Systems, Speakers & Accessories and more. We use science to evoke the true emotion behind every note.
            8 ch volume with tweeter and midrange amps for $400
            Konica Minolta Business Solutions Europe is your partner for smart IT services & systems, multifunctional devices & professional printing!
            No Fraunch required
            cheers,
            AJ
            Manufacturer
            • chasw98
              • 1360
              The BB op amps!
                • 15284
                No Fraunch required
                cheers,
                AJ
                I'd have to go with the Emotiva, as my balanced input Aragon's don't have level controls. Well, just for testing, might be an acceptable compromise. But what does IT sound like?
                • JoshK
                  • 748
                  I own the Emotiva, and am currently using it as a preamp (via bypass) while I finish some things up on the other system. It surprisingly is quite transparent and far better sounding than what I expected. HT gear has come a long ways since just 4 or 5 years ago when I started this hobby. Back then I owned a BK processor that sounded like @$$ compared to this.
                  It isn't a Burmeister (or whatever uber brand you choose) but it doesn't seem to get in the way either. For using as an 8 channel volume control, I think it should work well and it also offers HT features if that is what you need. Does anyone know what analog volume controller chip they are using?
                  • AJINFLA
                    • 680
                    Purely as a volume control? Where is the emoticon for opening a can of worms?
                    :argue:
                    cheers,
                    AJ
                    Manufacturer
                    • Mazeroth
                      • 422
                      No Fraunch required
                      cheers,
                      AJ
                      AJ,
                      The HK receiver. Doesn't that only have 5.1 analog inputs on the rear of it? From my understanding, you can only use a receiver like that for 5 channels of amplification. The .1 input is merely for outputting to the sub out (you gain volume control over it, that's all).
                      • AJINFLA
                        • 680
                        cheers,
                        AJ
                        Manufacturer
                        • Mazeroth
                          • 422
                          Beautiful!
                          Right now I'm using two Panasonic SA-XR25 digital receivers as my volume control/amplification for my DCX2496. The only problem is that once in a while they won't stay in sync when I use my remote control, but it's rare and quickly fixed by getting off my behind and adjusting it. They have almost no noise floor and sound absolutely fantastic.
                          AJ, what are you using with your DCX2496?
