6" Precision Ports
  • LunarD
    • 16
    6" Precision Ports
    I recently emailed Precision Sound Products, www.psp-inc.com, inquiring if they plan on producing a 6" version of their Precision Ports. Here is their reply:
    "We are hoping to have the new 6" Precision Port available in 2 - 3 weeks. We are currently taking pre-orders. These will be available on www.thrilleraudio.com by 9/5/06. I have included the pricing for the 6" Precision Port below.
    PSP-6OFN (Flare without mounting holes) - $14.33
    PSP-6RG (Connecting Ring) - $ 1.53
    PSP-6TB (12" plastic tube) - $ 6.10
    PSP6-OFN-5 (2 flares, 1 connecting ring) - $30.20
    PSP6-OFN (2 flares, 2 connecting rings) - $31.73
    PSP6-OFNT ( (2 flares, 2 connecting rings, 1 12" plastic tube) - $38.76
    There will be indentations on the back of the flare if mounting hole are needed."
    I have another email into them asking about what size tubes these will fit, and will post their answer when they reply.
    John
    "I have all theses great genes, but they're recessive. That's the problem here."
  • LunarD
    • 16
    Here is their reply on the tube size:
    "We did make the flare to work with a tube purchased from a plumbing supply store. The outside diameter of that tube was 6.293". You can try a tube that you purchase but we can only guarentee the tubes we sell. If you want to use our tubes you would need to purchase 1 extra tube and 1 extra connecting ring per unit."
    John
    "This one's tricky. You have to use imaginary numbers, like eleventeen ..."
    • Brandon B
      • Jun 2001
      • 2189
      Thanks. Was just looking into making some of these somehow. Buying is easier.
        They didn't try very hard to use standard sizes. Standard 6" pipe in the US is 6.625" OD with varying ID depending on the strength required. Around here, that's the only OD available but Thomas found smaller stuff somewhere so I guess it must be available where he lives. But, as the man says, you can always splice together however many 12" sections of the factory tubing you need to get the length.
        • Amphiprion
          • 886
          What is sewer&drain OD here in the US?
            The green sewer pipe is an industry standard. Some of the big box stores sell it. I get it from Lowes. The OD is just a hair under 6.25. That size fits inside the AeroPort flares perfectly.
            There are many sizes of 6" pipe depending on the 'schedule' of the pipe. So it will probably pay to go to a big plumbing company or if you live in a big city, someplace that specializes in plastic pipe to look at their 'boneyard' for scraps
            • Nonoises
              Thank You all for your interest in our new product. I see there is some misconception on the tube size. The tube we are using is a duplicate of a industy standard thin wall plumbing tube. However, since we can not control an "outside" vendors specifications we had to produce our own. Also, our tubes are BLACK ABS and therefore do not need to be painted which saves time. We could have created a flare that will fit the thick wall PVC tube 6.625". But this would add unnecessary material (and cost) to the flare and weight to the overall port.
              I hope this clears up some of your concerns. I am confident you will like our product and will see we did try to accomodate the DIY market in our design of the 6" Precision Port (tm).
              Steve
              President
              Precision Sound Products, Inc.
              www.PSP-INC.
              • Jack Gilvey
                • Aug 2001
                • 509
                Cool. Pricing is substantially lower than the older 6" flares I had. Sounds like there's a mounting flange, also, which should simplify things greatly.
                • collo
                  • 67
                  According to the Thriller Audio website, the 6 inchers are now shipping.... :T
                  Ports rule ...
                  • strevo
                    • 21
                    standard PVC
                    You could always just get standard thick-wall PVC and file the ends thickness down to fit the flares.
                    -Steve
                    • Jack Gilvey
                      2" Flared Precision Ports at PE
                      by Jack Gilvey
                      Precision Sound Products now has a 2" flared port available at PE. Somewhat different mounting arrangement than the 3" and 4" models.
                      Click on the PE banner at the top and search for "Precision Ports"...
                      28 September 2003, 06:57 Sunday
                    • Hirogen
                      Help connecting 2 subs to C2 balanced
                      by Hirogen
                      I have 2 subs and I have 2 XLR cables, both are 3 mtr long.
                      Connecting the 1st sub to the balanced "Subwoofer" output on the C2 works fine. The 2nd sub when connected to the balanced "Pro 1" output on the C2 does not give any sound.
                      I programmed the...
                      28 December 2004, 14:43 Tuesday
                    • PoorboyMike
                      Flared port connectors
                      by PoorboyMike
                      I went to Lowes last night with a 4" Dayton tube and a 3" Precision Port tube. I went to the plumbing section and found the 4" sewer pipe elbows fit the 4" tube quite well. 2 90 degree elbows hooked together form a nice, gentle arc and give about 19" of port length. I'll...
                      11 May 2007, 04:46 Friday
                    • Jeff Aguilar
                      My first tube amp!
                      by Jeff Aguilar
                      First step into tube amps…
                      Cayin TA-30
                      (alt+p)
                      I have not wire maintenance yet!
                      I bought a new amp a few weeks ago to try and improve my two channel music experience. About 8 months ago I invested in some Martin Logan speakers. I loved...
                      29 December 2003, 23:57 Monday
                      Zaph ZA5.3 MTM in a Steel Tube?
                      by ---k---
                      Crazy idea time. I'm stealing this from a post at the PE Forum by Spasticteapot. He wondered about using steel tube for enclosures. I'm not sure if he did anything with it, because he had problems getting tube steel. I'm a structural engineer - I don't have problems getting tube steel. So, today I picked...
                      19 January 2010, 14:26 Tuesday
