Hello...
I'm new here...been hanging out at AVS and "the goN". Glad to be here though!
I am building a 5.1 HT system in my basement. I would like to flush-mount all of my gear in a wall rack of some kind. There is a wall with a closet on the other side that I plan to use. The plan is to remove the dry wall frame it, and bolt in the rack. I'm trying to decide if I should get a Middle Atlantic pro rack (or similar) or build one out of plywood. Obviously wood would be cheaper; but the pro racks look cooler.
Does anyone have any thoughts either way?
Thanks!
Thanks!
