So I am new to the whole DIY loudspeaker thing, but this is what I am looking to do. I want to build a threeway tower speaker that will sound much better than the JBL e90 Towers which are TMWW araingement with dual 8" woofers. Anyway, I work for the largest consumer electronics store in the U.S.A. as a sales person in the Home theater department and I have come to realize just how bad some of the stuff that we carry sounds, hence the reason for me wanting to build my own in hopes to get something better for about the same money. Plus it will give me bragging rights because I can say, "hey I built this myself for less than you spent and it sounds twice as good" .
Anyway I was looking to spend hopefully less then $500 on the project(drivers and crossover components), which is about what I could get the E90's for. I was hoping to do a TMWW similar to the E90's but with a much more detailed sound and a higher F3 at about 55hz in a sealed encloser. Also I would like to follow the K.I.S.S.(keep it simple stupid) mentality on the crossover, because that way I have less stuff I can mess up. I was looking at doing 2nd orders for everything and my crossover points were selected accordingly, but I am very open to suggestion.
I have been reading all sorts of DIY speaker stuff for the past 6 months and I feel I have a pretty good grasp on the basic stuff, but I am extremely far from being an expert like some of the people on this forum. So don't dumb things down to much like I have to do when I sell TV's and Audio stuff to the average person.
The drivers I had planned on using are as follows:
DAYTON PT2B-8 PLANAR TWEETER, $32.00 Each
I liked this tweeter simply because it had higher sensitivity and it was described by a few people to sound detailed and open, plus it looks kinda cool. I was looking at a XO point at somewhere between 3Khz-3.5Khz, mainly because that was suggested in its specs. I am open to suggestions on this one, but I would like to keep it in the general price range of this.
Peerless M 122 (821615) 4" poly cone Midrange, $37.00 Each
The fact that it is chamber looked nice, smooth frequency response and impedance. Only thing on this that I question is if the Poly cone will sound ok with the other drivers. If anyone has used this driver, some insight would be greatly appreciated. I am also open to suggestions on this one, but with the same criteria as before. XO points same as High and low pass on tweeter and woofer.
DAYTON RS225S-8 8", $41.00
Basically every review I found on this one said it was the best bang for your buck woofer out there, but with only on drawback. Its got a nasty ugly little dude at about 1.5 khz. I am planning on using two wired in parrallel to get the predicted 6db gain and also I am looking at a crossover point somewhere between 500Hz-600Hz. Also, this will need a Zobel network or something to that effect. I am pretty set on using this driver.
Well basically I am looking for suggestions on the Tweeter and Mid, are there better drivers out there for about the same money? Also some help/suggestions on the crossover would be greatly aprieciated.
What I have figured out so far is the box volume of about 2cu.ft. sealed/stuffed which should have an F3 of ~ 55Hz for the woofers, I chose this because I like the way sealed boxes sound and I have two 12" subs to add as much bottom end as I feel there is a need for.
These speakers will be used for both music and movies and powered eventually by a Yamaha HTR-5790 Reciever which handle some pretty low ohms(like 2ohms) and not go into its power protection mode. They will be have to be placed about 2"-3" from the wall as college appartments don't have listening rooms, but I figure at least then I would have to worry about baffle step compensation?
Also, I realize that with 2nd order filters and the XO points I have chosen there will be like a 3dB gain in the midrange, but I figure hey 91+3=94, just like the tweeter and woofers so maybe I won't need to pad anything?
Looking to get good detailed sound, and not spend a fortune. I am in college so budget is a big issue, so no Diamond tweeters for me :cry: , but I would like to get the best that my money can get me and I guess that is why I chose to go DIY in the first place.
SO any help, comments, suggestions will be greatly appreciated because I don't have the money to buy LEAP or CLIO or anything like that, but I do have time to tinker with stuff until it sounds good. Well thanks for reading, I am looking forward to hearing some suggestions.
