A true Progressive output?
  • KennyG
    • Sep 2000
    • 746
    As I understand it todays progressive scan DVD players don't actually output a true progressive signal, it's doublelined, and the reason for this is the signal coming off the disc is actually interlaced during the MPEG decoding process.
    If this statement is true, do all MPEG decoders have to interlace the signal during decoding?
    If this is true of stand alone DVD players, is it also true of HTPC?
    • 16176
    Hi Kenny,
    Line doubling means just that- taking an interlaced video signal, doubling each frame by shifting it down, and scanning that out as a progressive signal. Some "doublers" do just that, but not in a "progressive scan" DVD player, and not in an HTPC, normally.
    There are two types of "source" material on DVD's: film and video. Film is stored in sets of 24 interlaced frame pairs, with SMPTE codes identifying the frame pairs. A progressive scan DVD player or an HTPC checks the frame codes, assembles the matching frames, producing 24 frames per second of progressive material, and then plays them back using 3/2 pulldown if 60Hz playback is used (as for TV's, with a conventional progressive scan DVD player), the same happens in an HTPC IF 60Hz refresh rates are used; ideally, though, a refresh rate at some multiple of 24 Hz should be ussed, so that a simple integer multiplication of 24 FPS is used. Now, the situation can be complicated by factors such as the incorrect MPEG frame codes existing on the DVD; this DOES occur, from time to time, and the some of the newest players (such as the Sony DVP9000ES) have circuits to watch the vide frames, compare them, and detect and overide "bad" codes.
    For video, life is more complicated; on PC's, either bob or weave is offered; bob will effectively halve the vertical resoultion, and weave of course can still have some of the artifacts that result from motion in an interlaced field; the best systems uses some spatial filtering, to smooth and interpolate between the two frames; this lowers vertical resolution slightly, but is perceptually less objectionable than simple BOB.
    Have a good weekend,
    • KennyG
      • Sep 2000
      • 746
      Alrighty then...one more question...why don't today's "stand alone" progressive DVD players offer switchable frame rates? Something like 72 or 96hz for film based movies, switchable to 60hz for video based stuff?
      I'm assuming HTPC does do this...
        • 16176
        Because, todays DVD players are designed to the home entertainment specs, for SDTV resolutions, all of which specify a 60Hz field rate; same for 1280X720 HDTV and 1080I HDTV. All run at the same vertical scanning frequency, and only change the horizontal freuqnency. Horizontal frequencies are 15.75 kHz (480i), 31.5 kHz (480p- SDTV and progressive DVD), 37.5 kHz (1080i, 540P), and 48 kHz. Graphics and data grade front projectors are multiscan devices, like computer monitors, and can work at a variety of vertical scan frequencies.
        There's a German progressive mod board to DVD players, which does support scaling to higher resoultions, and higher vertical refresh rates, and it will provide a good signal for multi-scan monitors and projectors, but you can't drive a conventional HDTV set at higher than 60Hz.
        • KennyG
          • Sep 2000
          • 746
          Thanks Jon, I forgot to mention, I was thinking of FPTV when I wrote that last question, hence the "switchable refresh rates" question.
          Since I've just sealed a deal on my first projector, I'm putting together thoughts on HTPC, and what I want...or need mine to do.
          • Karma
            Progressive Vs. Interlaced Scanning
            by Karma
            HI All,
            We all grew up with interlaced video. Even now, most TV's use interlaced horizontal scanning systems. It is the system I am familiar with. A few years ago I started hearing about progressive scanning monitors mostly related to computers. I understood that the advantage to progressive...
            05 June 2006, 12:23 Monday
          • Clive
            Home Theater Glossary
            by Clive
            G'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
            I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...
            11 July 2005, 22:38 Monday
          • spyboy
            When Did You Get Your First Progressive (Line Doubled) Display?
            by spyboy
            I had first been reading about HD TV around 1989. In 1990, Toshiba released the CZ3299K, a 32 inch with what the brochure describes as "Frame memory double scanning non-interlaced picture."
            I could not resist. In September of 1991, I took the dive to the tune of $2,400....
            01 January 2006, 11:19 Sunday
          • Henk
            RSP 1098 and progressive scan dvd/dvd audio players
            by Henk
            The RSP 1098 TFT screen displays no video unless a usable signal is passed through the composite video connection. However, as pointed out in the RSP 1098 manual not all dvd players, set in progressive mode, output a usable composite video signal. This is true also for dvd players that play dvd audio....
            21 November 2003, 05:55 Friday
          • McLovin
            1068: Problem switching between progressive inputs
            by McLovin
            G'day,
            I am having an issue with my RSP-1068 and progressive scan inputs.
            I have three video input devices hooked up to the 1068: a set-top box, a DVD player, and an Xbox (on V1, V2, and V3 inputs respectively). The 1068 is then connected to my TV (a Sony LCD). All inputs...
            16 June 2008, 08:45 Monday
