What OS?
  • rudee
    • Oct 2000
    • 37
    What OS?
    Het what's the best/most stable OS to run a dedicated HTPC with? I have win2k pro, Windows 98 and ME? I started to install 2k on my PC but ran into way too many problems and went back to 98. I just got the ME step up from 98 but haven't done anything with it. Which would be best? Thanks
    rudee
    • 16176
    That's an interesting call. For now, I'd have to say it's between ME and 98SE, because WIN2K doesn't support DD over SPDIF yet.
    Between ME and 98SE, that's harder- I've got one of each (the ME thing is more of an "experiment"), and I find there are improvements in the stability of some some media code, and networking has been improved. Plus, the configuration restoration trick can be quite useful- basically, once you get to your fully functional main configuration, save that, so you can restore to that functional mode in case of making any major changes- like installing a remote keyboard, or an HDTV board, etc.
    The main thing I don't like about ME is the lack of any DOS box; for some things, I'm always going to have to have 98SE around.
    On the ME system, which is in my bedroom, WINDVD and Baludur's Gate II are the prime applications, with a couple of flight sims. Video card is Elsa Gladiac, and the system is a DIY ASUS A7V with 750MHz processor (low end these days, but not when it was built)
    UI overall is slightly more polished, and slightly more annoying, in terms of wanting to dumb stuff down for the end user.
    • Lexman
      • Jun 2000
      • 1776
      Good advice Jon. I am sure you know this area far better than I. I can only say that configuring my 2000 box, without DVD has been a real experience. I dread the day I have to reconfigure this beast. But I can say, it's the most stable computing environment that I have ever had at home for web development. I can also say that it's the fastest. :B
      Anyway, I would probably go with 98 SE if I had that option for an HTPC. I think I have 98, but don't think it's SE.
      Lex
      • KennyG
        • Sep 2000
        • 746
        I'm using windows 98SE and so far it's been fairly stable, powerDVD was extremely stable running in 98SE, winDVD has been less so, but Jon is sending me a patch for winDVD, mine is an older version.
        So I expect better stability using winDVD soon!
          • 16176
          BTW,
          I've downgraded my ME system back to 98SE, while installing a new Fujitsu disk (the relatively new Maxtor drive started degrading then died over a couple of week period) - some glitches that occured with a few programs on an intermittent basis are now gone.
          ME is a mixed bag; there are some "improvements", as previously reported, but these improvement "broke" a lot of drivers and programs, and all in all, (particularly for an HTPC) I think stability is more highly valued over some tweaks in the netorking code (which isn'tused in this system!)
          Note, some multimedia products, such as the HiPixx HDTV card, *require* 98Se as the minimum operating system.
          Happy weekend, folks!
          -Jon
