HDMI split to HDMI video, and Digital Coax or SPDF optical output component
    • 27460
    I really have quite the mess after dropping DTV or Ruined ATTV.
    If I watch Amazon Prime, or any other service, I have to just use the audio on the TV, because it is not compatible with my Lexicon.
    I would like it to be as robust as possible, not some cheap little POS.
    I do have some cool HDMI splitters. I just have to press a button to go between Roku and Fire TV on 2 devices. It's mind boggling figuring all this out, especially when you have 2 TVs. Aa 4K and a Plasma 1080p.
    I found this, it seems like I can control inputs with my splitters into the HDMI input, and then take advantage of digital or analog output. Do you guys agree that this is the ticket, or do you know of a better device?
    I would really like to have as sophisticated of a device as possible, even 2 HDMI inputs, etc... But I think I can figure out the splits on the front end to at least 1 TV, maybe with 2 of them, I could handle both TVs I have duplicate Roku and Fire TV modules.
    Thanks for any and all advice!!!
    This is the best option I have found so far..
    • 27460
    I just ordered the inexpensive box yesterday with optical out and stereo out and HDMI through. Hopefully I can think my way through the connections and switching to make it all work. If not, I will only go to 1 TV not two. I already have some switching going on back there from my DVD player outputs to multiple TVs. We'll see, it may wind up being switching and just swapping an HDMI cable to go from fire tv to DVD. Roku not used so much anyway.
    • chrisc
      How 2 hook up 2 HDMi TVs w/ Denon 3808/ Sat. box
      by chrisc
      Hi. Trying to hook up a satellite box with only one hdmi input to 2 tvs that both have hdmi inputs. The sat. receiver is in the living room with my big tv and i want to split the Sat. box to the Bedroom tv which also has an hdmi input. I also have a Denon 3808 stereo receiver that has 4 HDMI inputs...
      31 August 2008, 20:42 Sunday
    • markyboy56
      best 5in1 hdmi splitter
      by markyboy56
      hi
      i am after buying a 5 in1out hdmi splitter with the very latest specs
      ★4K ULTRA HD 5 IN1 OUT: This HDMI Switch connects up to 5 UHD HDMI sources on a single display and easily switchs between 5 sources. Support bandwidth 18Gps/600MHZ, HDCP 2.2, 4K 60HZ 4:4:4, FullHD,...
      09 March 2018, 12:29 Friday
    • raysam
      RSP 1570 and HDMI splitter
      by raysam
      Has anyone found a HDMI splitter that works with the RSP 1570?
      I’ve tried both Audio Authority’s and Gefen’s 1:2 HDMI splitters and both exhibit various handshaking problems, where one or both displays will not display correctly.
      Both splitters work well when splitting...
      18 November 2009, 14:09 Wednesday
    • Dean McManis
      "Digital" TVs, deciphering the terms.
      by Dean McManis
      "Digital" is a buzzword today, and it is regularly abused. Most "digital" cable is NOT transferring high definition digital signals, but they are transferring the 480i NTSC analog signals into digital format, so that they can compress them, to get more channels across the line. So...
      06 June 2003, 18:27 Friday
    • OldMan
      4x4 HDMI Matrix splitter
      by OldMan
      I have been doing some research on purchasing a 4x4 HDMI matrix splitter and one common problem plagues them all. And when you think about it, the problem makes perfect sense and can NOT be fixed. (But you can get around it, see below)
      Let’s say you have two TVs. One is 3D capable and...
      10 July 2016, 10:42 Sunday
