Announcement
No announcement yet.
Marantz rc 3200 and Lutron SPACER system
  • Filter
  • Marantz rc 3200 and Lutron SPACER system
    I have an rc3200 remote contriol,I want to program my
    Lutron SPACER light system,I have the codes installed in the 3200 when I
    go to program the light switches for scenes or turn them off via the remote
    it does not work,I can however toggle the brightness of the lights up
    and down,I should also add that I am using an ir repeater system and it
    indicates that it is receiving the code any ideas as to why I cant do
    what I have mentioned? I have also contacted the mfg of the light
    switches and they have said that it might be the remote it self (some
    kind of bug) EVERYTHING else I have programmed into the remote so far
    has worked, I have downloaded from remote central that code is NOT for a SPACER system.Thanks in advance.
    DarrenBR
  • #2
    Darren, the next thing I'd suggest is to contact Marantz. They should be able to tell you if a bug exists or if your remote is suspect. Good luck.
    P.S. Sorry we didn't respond sooner.
