I recently purchased a new rotel receiver and i am using my old yamaha in my office. i want to hook my computer up to it so i can listen to music through it in my office. i bought one of those adapter that takes rca's to a mini stereo jack. There is a SIGNIFICANT amount of noise/humming. The even weirder thing is that I currently have a splitter coming out of the computer so i can still use the speakers that came with the computer and the noise/humming is even transfered to them when i have the receiver attached. It has the noise even if i attach the receiver directly without the splitter or original computer speakers. Do I need a better shielded cable? Any suggestions otherwise?
Computer to receiver
Quick thoughts: 1. Check your audio settings on your audio card as well as your Window settings. 2. Update your Sound card software. 3. Ensure you have the splitter on the correct audio output and it has been configured properly for playback.
Peace and blessings,
Azeke- Bottom
If you want the best quality out of your reciever, the better link would be using digital output from the sound card to allow the sound card manipulate the signal as much as possible. There are some low cost cards out there which use Envy 24HTS chip that are around 30ish would do the job :TPioneer KRP-500M
Emotiva UMC-1
Parasound 5125
Oppo BDP-83
Klipsch RF-3II, RC-3II, RB-5II
SVS PB-10NSD- Bottom
Check all of your connections. I've had some issues before with the cheap mini to RCA adaptors. Sometimes they seem a little thin and don't hold as tight as I'd like to see - this causes the ground to sometimes lift.
You could also try a card with RCA connections - I have an external USB card now (~$35), it happens to have a toslink connection, but I could also use RCAs if needed.Danish- Bottom
I'll bet it's a grounding issue between the PC (most likely the problem) and the receiver. I had the same problem. My option that I ended up with was going optically from the PC to the receiver. That completely resolved the problems.
The wired connections is causing a ground loop type of issue.
-Dan- Bottom
That's my guess, ground problem. I agree with using an optical digital connection to the receiver or investing in a quality internal or external soundcard with analog outs and eliminate the splitter.Originally posted by PewterTAI'll bet it's a grounding issue between the PC (most likely the problem) and the receiver. I had the same problem. My option that I ended up with was going optically from the PC to the receiver. That completely resolved the problems.
Jason- Bottom
Here this is what I do, and there is no noise at all. I use a Creative USB external sound card, I have my laptop hooked up to my reviever via Coax. Check out this link,http://www.newegg.com/Product/Produc...82E16829102174, this should work perfect for what you want to do."Yes, but these go up to aleven" Spinal Tap
RH
:-y- Bottom
by pboneI need a sound card with AC3 pass through and SPDIF out. As far as I can gather my current sound card (sound blaster live value) can't do this. I gather the Sound Blaster Live 5.1 can do it, although apparently its digital output voltage is considerably higher than the SPDIF standard. Creative claims... -
by SteveGAs some of you may know from my previous posts, Immersive, Inc., has introduced a PCI video processor card featuring Faroudja’s patented DCDi processing. The HOLO3DGRAPH is designed to accept Serial Digital Interface (SDI), Component, S-Video, and Composite video inputs. It combines with your PC graphics... -
by bniemanI just bought a pair of N805 bookshelf speakers for use in my home office which I am running with a Rotel RC-995 Preamp and RB-9808X amp. I love it already but my sound card is the weakest link in the chain. I am currently using a Sound Blaster Audigy 1 as my source from the computer.
Channel: Club B & W Speakers
by nelsondogCan you recommend an inexpensive PC sound card card for testing/tuning a BFD IB system? I guess I'll need a mike too.
Thanks in advance!
Brian-
Channel: Mission Possible DIY
by Chris DWell, my PC is coming up on being 4 years old, and is showing some age. Now may not be the time to replace it, but if I do, I'm considering building my own. I've never done it, so I'm a little apprehensive. In general, I'm great with learning and building things, but am not sure where to learn from... - Loading...
- No more items.
