I purchased a Sony STR-555ES reciever without the original remote. I use a Sony RM-AV2100 remote commander to run it. Speaker set-up requires white noise activated by a button on the original remote. How can I simulate this function with the programmable AV2100?
Sony STR-555ES no original remote
Sir Wildman,
Question: The remote does not provide the option once you select the Sony Code choices (001 or 002)? Perhaps the option may be hidden deep in the Sony menu, be sure to try both codes.
If not, I would contact Sony support and/or go to remotecentral.com to see if there is an answer available.
Just my quick thoughts, I'm sure others here can provide advice.
Peace and blessings,
Azeke- Bottom
by Chris DFor those who were asking, here's a "hard" copy of the review. This PJ is one that I've been looking at for a while, and finding good stuff.
Sony VPL-HS10 Video Projector
Champagne Video On A Lemonade Budget
By Greg Rogers
by wettouSony Delivers the Ultimate Home Cinema and Multi-Channel Music Experience With Its Latest ES Family of Products
Three New Products Combine to Give the Very Best in HD Home Entertainment
BERLIN--(Marketwire - August 28, 2008) - IFA
-- High-end system of Blu-ray Disc...-
Channel: Audio Hideout
by delonerThe remote RR949 that i got with the RSP985 didn't work when i got it.I got a replacement 939 today, but it wont work! I hold audio +mute and after 1-2 sec the audio button flash red.I then have 20 sec too put the code 001-002 to controll the 985.I do this, and nothing happends.It looks like if it is...-
Channel: Club Rotel
30 September 2003, 09:57 Tuesday -
by Tha FreakMy mother want to buy a Sony 34" above listed...
any owners or comments?
here's the specs:
Turn your home into a cinema with the KV-34HS420 34” widescreen Hi-Scan 1080i™ television from Sony. Combining a high-quality 16:9 FD Trinitron® picture tube... -
Just hooked up my Musical Fidelity A5 integrated amp, and realized that their remote is really funky. My Sony, Rm-VL-900 learning remote cannot learn the commands. I read something about some remotes have a parity signal, that changes everytime you use a function. All I know is that you can only use...-
23 December 2006, 22:21 Saturday -
- Loading...
- No more items.
