Sony 34HS420 34" crt hdtv...HOW GOOD?
  • Tha Freak
    • Jul 2003
    • 385
    My mother want to buy a Sony 34" above listed...
    any owners or comments?
    here's the specs:
    Turn your home into a cinema with the KV-34HS420 34” widescreen Hi-Scan 1080i™ television from Sony. Combining a high-quality 16:9 FD Trinitron® picture tube with a Hi-Scan 1080i™ display and DRC™ Digital Reality Creation™ multi-function circuitry, the KV-34HS420 produces visuals like no other.
    The KV-34HS420 also features simulated TruSurround™ SRS® and Steady Sound™ automatic volume control with BBE® Audio Effect for a breathtaking theatre-like audio experience. It also includes other high-end technology, such as CineMotion® Reverse 3-2 Pulldown technology, a high voltage regulator, and a DVI-HDTV interface.
    Digital Reality Creation™ MultiFunction Circuitry analyzes a 480i NTSC image and creates a digital bit mapped pattern in real time. The original NTSC signal is mapped in real time, replaced with an HD repersentative and then discarded. Because DRC™ processes video signals in real time, it creates an image with 4X the density of the original signal. Resolution is increased both vertically and horizontally.
    CineMotion™ 3-2 Pulldown improves the display of video programs originally shot on 24 frames per second film preserving the integrity of the original film frames for more fluid motion and more fine detail.
    Audio:
    Simulated TruSurround® Audio (10W x 2)
    Steady Sound™ Automatic Volume Control With BBE® Audio Effect
    Auto SAP
    Audio Output (Fixed/Variable)
    Video:
    Dynamic Focus™ Circuitry
    Dynamic Picture™ Circuitry
    Trinitone® Color Temperature
    ClearEdge VM™ (Wideband Velocity Modulation Scanning)
    Vertical Aperture Compensation
    Vertical Center Adjustment
    3-D Digital Comb Filter
    Auto Program
    Caption Vision (CC)
    Channel Fix
    Channel Label
    Channel Skip/Add
    Clock/Timer Two Event
    Energy Star® Compliant
    Favorite Channel
    Front Button Menu Control
    Channel Jump
    On Screen Display (English/Spanish/French)
    Program Palette™ (Vivid/Movie/Standard/Sports) presets
    Tilt Correction
    Sleep Timer Function
    Speed Surf™ Channel Selection
    V Chip Parental Control
    Video Label
    Auto Pedestal Clamp
    Auto White Balance
    Vertical Correction
    Vertical Size Adjustment
    General:
    Power Consumption
    (in Operation): 240W
    (In Standby): 1W
    Power Requirements: AC 120V 60Hz
    Inputs and Outputs:
    Component Video Input (Y/PB/PR): 2 Rear
    Composite Input: 1 Front/3 Rear
    A/V Inputs: HMDI: 1 Rear
    S-Video Input: (With Detection): 1 Front/2 Rear
    Control S: 1 Rear
    Audio Output: 1 Rear
    Monitor Output: 1 Rear
    Supplied Accessories:
    Instruction Manual
    Remote Control (RM-Y197)
    AA Battery (2)
    Weight:
    87.8 kg (193 lbs 10 oz)
    Dimensions:
    994 x 654 x 604 mm (39 1/8" x 25 3/4" x 23 3/4")
    "Are you gonna bark all day little doggy?...or are you gonna bite?
    Twin Moderator Emeritus
    • 16706
    Don't own it but Sony make nice TV's, if a little overpriced compared to the competition
    • Victor
      A fully Digital Volume Control for the DCX2496 users
      by Victor
      I while ago there were many discussions regarding the implementation of the volume control for the DCX2496. I use the combination of the DEQ2496 and the DCX2496 to realize most the EQ needs of my full range 3-way dipole system. Until now I have been using two motorized 4-gang pots from Alps. The pots,...
      31 July 2005, 11:46 Sunday
    • grit
      dynamic range control question
      by grit
      On my Rotel 1560, there are 4 settings for Dynamic Range Control (for Dolby Digital, True HD, etc). Min, Mid, Max, and Auto.
      What does "auto" do??
      Max means no dynamic range compression, correct?
      I get how dynamic range control works, but aut...
      20 June 2011, 17:24 Monday
    • augerpro
      Symmetro: a proof-of-concept
      by augerpro
      Thought I'd share a project Derek (deschu) and myself are working on. This started with my experience that despite the technical shortcomings of the MTM, I often really like their sound, better than an identical TM at times. I'm not the only one and I think the assumption is that there is reduced sound...
      22 January 2017, 19:19 Sunday
    • okcorrell
      Install auto on/off relay inside active speaker
      by okcorrell
      I wanted to reach out for some help to some seasoned DIY audio people.
      I have several 5" Monoprice powered monitors paired up with apple airport express' for a makeshift multi room system. It works perfectly as each book shelf speaker is independently powered...
      26 February 2014, 15:09 Wednesday
    • Wireless
      Toslink auto switch
      by Wireless
      I just received my second 400 disc Sony cd changer for use with my pc and slinke control system. I now need an auto switcher for toslink connection. I'm familiar with the DXS from Nirvis, but along with the MSB Digital Director these are $500+.
      Does anyone know of a toslink automatic switch any...
      10 April 2001, 08:28 Tuesday
