For those who have been infested with the nasty, difficult to remove Elite Toolbar (pokapoka##.exe), I found a tool that will remove it for you.
Download it from here: http://users.pandora.be/bluepatchy/m...ools/LQfix.exe
After downloading it, run it. It will install and run a file called BFU.EXE (which stands for Brute Force Uninstaller
). It will then prompt you to reboot. When you reboot, it may take longer than usual to reboot, but what it's doing is removing the spyware before Windows loads.
