widescreen monitors...and WMP
    • 16478
    Ok so I've now got this nice 15.4" widescreen laptop and I figured lets see how movies look on it...only to find that I can't seem to get them to fill the screen as they're all letterboxed. I've maximized the window and told WMP to go full screen but it seems to be stuck thinking that i have a 4:3 aspect ration screen...any work arounds for this?
  • Kevin P
    • 10812
    DVD movies? I'd use something like PowerDVD instead of WMP for those.
      Twin Moderator Emeritus
      • 16706
      Yeah I agree use Power DVD etc but also, what video drivers do you have loaded?
        • 16478
        This machine uses the new integrated Intel video card so its using the latest drivers from the Dell site. I have Power DVD and they play at full screen using that software so I think there has to be a setting somewhere in WMP to get past this issue.
          Andrew, I'm not sure whazzup. I thought there was a setting in WMP for that, but I just checked and I can't find it. Mine automatically shows widescreen on my widescreen Dell.
            • 16478
            Hmm which codec are you using Chris?
              I'm running version 10.00.00.3646, which is the latest. Is that what you're asking? The WMP seems to interact with my Power DVD also, which I've updated to Version 6 Delux. (also the latest and greatest with DTS support, etc)
              Mine has always run full screen with widescreen material, though, since I first got the laptop.
              • Mr. Mxyztplk
                • 18
                I am having the same problem. So far it appears that there isn't any aspect ratio control on the player.
                  • 16478
                  Gord Moore sent me this link that might help us.
                  Or maybe there's something in this app.
                  Find help and how-to articles for Windows operating systems. Get support for Windows and learn about installation, updates, privacy, security and more.
