Please help my supervisor
  • goskers
    • 106
    Hello All,
    I was just approached by my boss to find him some help in regards to a new TV purchase. He would like a monster even though his seating distance is only 13ft away. A 60" set would be around the optimum size that we are looking for. A lot of dvd's, hi-def satellite and regular satellite channels are what he watches the majority of the time. To give you an idea, he has 3 200 disc progressive scan dvd changers that are full. At the same time, regular sat channels must be watchable.
    Absolute max limit is 8K. He is also open to waiting til next summer before the start of the NFL season. What can I say, we're in WI.
    Any advice is welcomed,
    wasser
    Twin Moderator Emeritus
    • 16706
    I still recommend CRT RPTV's as they still offer the best PQ IMO not to mention they're dirt cheap They can be on the big side though.
    DLP based RPTV's would be my next recommendation.
    If he has a light controlled room, I'd recommend a long look at a front projector even in conjunction with a smaller "regular" display.
    I think more info on his decor, size restrictions, light control etc is needed to give the best recomendation.
    • goskers
      • 106
      Thanks Jason,
      I just got done reading Bing's giant post regarding his toshiba hx93. That has even gotten me to think about jumping into this game.
      I will try and get more info in regards to room conditions and such because I know that that will help.
      I seems to be that NTSC signals just don't look very good on high quality, larger screen TV's. If that is the case then I hope the highdef channels come along very quickly.
      wasser
        • 16706
        No problem Let us know when you've got more info
        • Shane Martin
          • 2852
          It's a case of crap in crap out. Luckily if he is a football fan, they are all in Hi Def(except College).
          I would recommend a Mits 65" CRT RPTV but if he can do a front projection, I would. That said if he bails on both options, then a JVC DILA Is the next best bet IMHO.
          Personally I can say that I'm happy with my Mits 55" set and the picture for non HD stuff is VERY watchable(after alot of tweaking). Removing the protective screen made a nice improvement(probably the biggest). I have also dialed in the contrast etc. All I lack is a solid once over by an ISF Tech. He could easily get a 65" Mits for under $3k.
          He can then take the 5k extra and boost his audio system which is what I did(though not that much $$).
          65" at 13 feet back would be perfect.
            Gotta agree with Shane on this. I'm viewing a 58" at approximately 11' and it's perfect for me visually.
            • BlazeMaster
              • 644
              are you talking about 13 feet of room altogether not including the TV in there or 13 feet of viewing distance no matter what TV or display you use. A typical 65 inch RPTV is about 2 feet in depth, so you have the take 2 feet off the 13 feet.
              Shane Martin, did you remove the protective screen yourself? I have a Panasonic 53 inch and I've been wondering what it'll take to remove it and get rid of some of the glare I get when I watch it when there's light in the room. I don't like watching TV in a completly dark room, and that glare is just so annoying. Can a ISF tech remove the screen for me and do a calibration at the same time?
                Raymond, yes removing the protective screen will cut the glare. The ISF tech can do it if you don't want to tackle the job. However, it's on there for a reason. If you have small children, very active pets or host rambunctious house parties, I recommend leaving it in place.
                Also, I'll bet that the 13' mentioned is to the screen. Normally, you consider the distance from the screen to the veiwer's eyes.
                • Sonnie Parker
                  VOOM Satellite is busting loose!
                  by Sonnie Parker
                  Voom is really makin' some noise in the satellite world. Especially in the HD area as they are now up to 37 HD channels (21 of those exclusive to VOOM) and have more on the way in June.
                  We've posted a little on this in the past but they haven't had much offering up until recently....
                  07 May 2004, 15:56 Friday
                  Satellite Radio (XM and Sirius)
                  I'm curious who has experienced satellite radio, and what comments you could make. Obvious attractions for using it would be national radio reception, diverse programming, and perhaps portable capability.
                  But how does it SOUND, man, how does it SOUND? From what I understand, the audio...
                  31 March 2004, 13:10 Wednesday
                  Chroma Bug on Hughes E86 satellite receiver?
                  I bought a Hughes E86 HDTV Satellite Receiver from Good Guys a few weeks ago. They're having a sale on them for $399, brought down even further to $299 if you buy any HDTV.
                  So far the set has been great. Others have reported local channel reception being dropped by these units, but I...
                  02 August 2003, 18:47 Saturday
                • Stu
                  New Home Construction, Wiring For Satellite
                  by Stu
                  I am wiring a home for satellite for the TV/Home Theater. It is new home construction and no dry wall has been put up yet. I plan on running wires from the access point to the house and make home runs in the wiring from a video splitter to each room. There are eight rooms that I will be making home...
                  14 July 2004, 16:12 Wednesday
                • hamiltong
                  Another - RMB 1095 Ground Loop / Satellite
                  by hamiltong
                  Like many others before me - after installing all my new toys (RSP 1068 & RMB 1095) - I now have the infamous ground loop hum. God it's annoying.
                  It's definitely attributed to my satellite coax feed. When unplugging the coax from the SAT receiver hum is gone. Or unplugging the S-Video...
                  31 March 2004, 23:34 Wednesday
