Can anybody help me here? Last night I left my Sanyo Z2 on with the DVD player's screen logo on for about 15 min. DVD player is a Smasung HD931 and the logo says "Samsung Digitall - everyone's invited". So at about 15 Min, the logo turned red, I then turned off the projector and let it cool down for an hour. I then played a movie and the logo was visible in the background. Tried with a different DVD player but the logo was still there, the picture was displayed fine but the logo was in the background. Anybody have an idea of what this could be? Is the logo burned into one of the LCD panels? Any help would be great.
Z2 Burn in on LCD Panels???
That is awefully fast for this to occur. Scare's me,that's for sure. I know my 2HD cuts off if it doesn't receive a signal within a set number of seconds. I guess your DVD player kept it from doing that? I would say this is a real problem. I beliver you need to contact Sanyo.
LexDoug
"I'm out there Jerry, and I'm loving every minute of it!" - Kramer- Bottom
LCDs aren't supposed to burn in (at least not permanently), but it's possible for LCDs in projectors to suffer heat damage. What was the color of the logo and the lettering?
It shouldn't have happened that fast though. If you put on varying material, has the "burned" image started to fade?
Is the projector in a hush box, or anything that could interfere with cooling?- Bottom
Thanks for the input guys. My DVD player which is a Samsung HD931 has a screen saver that starts after about 5 Min. when there is no play, so yes this is really weird that this happened so fast. It was on the screen logo and just as it was about to start the screen saver, the logo which is in white lettering on a blue background, turned red, after about another 5 min with the red image I turned it off and let it cool down. Yes I played about 5 different movies to see if it would go away but no luck. I do believe the image has burned into one or all of the LCD panels, don't know if this is possible but that's what it looks like to me. I have contacted Sanyo and they are going to repair it under warranty. They tell me 2 to 3 weeks, is that right? I though they had a quicker turn around time.:righton:- Bottom
If you put an all-white image up (say a 100 IRE gray field on VE or Avia), do you see the burned image? What color is it?
If you put an all-black image up (black field, or 10 IRE gray), do you see the burned image? What color is it?
The answers can help us determine which of the panels was affected.
At least they said they would repair it under warranty.
Another possibility I thought of is a faulty LCD drive circuit can cause "burn in". I've heard of this happening on some Dell laptops. Did Sanyo say anything about this happening on any other units? Is it a common problem?- Bottom
It would be really weird for it to actually be "burned" in.
We see a lot of "stuck" images in LCD PJs we install, but they have been showing a static image for 15-20 minutes out of every half hour, 16 hours a day, 7 days a week, and it doesn't occur for a month or 3. And they can usually be "unstuck" by playing other material for a couple of hours.
I would have said what happened to yours is impossible if asked theoretically. I wonder if it is an actual burning phenomenon of some sort, or some issue with the drive electronics.
Please definitely let us know what turns up.
BB- Bottom
I am dropping off my unit at Sanyo today, so I haven't yet explained to them the problem, I am curious to know what they say about this, considering that my unit is new only 161 hours on it and 2 months old. The so called "burned image" cannot be seen on dark scenes it is not even vissible on bright scenes, it appears when there is more than 3 or 4 ranges of colors displayed during a scene. I don't think it is a burn-in issue either and agree with you guys about it being a circuit problem. I will surely come back here with the details of the whole repair process and what the problem is and what may have caused this.:righton:- Bottom
Yeah, I think that "burn-in" is a misnomer. I've also run my LCD rear projector for days straight with a fixed image, and also played games with white lettered fixed graphics and scores for many hours with no effects. 8)
It might be some memory buffer effect, or something particularly wrong with your unit.
But if it's some sort of design flaw with the Z2 it would great to know about it, because the unit has otherwise recieved great praise. :B
-Dean.- Bottom
Hello all. Just got my Z2 back from service. 3 day turn around! Pretty good. They actually had alot of questions for me about how this happened because the people at the Sanyo warranty division have never seen anything like this and the technicians had no idea what could have caused this, basically this had them all scratching their heads. The guy I spoke with told me it wasn't the LCD panels that were "burned" but something about the lazer, I didn't quite understand him because he wasn't the technician. Anyway they repaired it under warranty and all is well.:righton:- Bottom
Sounds like he was bluffing, or you misheard him, since there is no laser in the projector. Maybe he meant the polarized sheets over the LCD panels? Maybe they overheated or something and had the image "burned" (or melted) onto them? If that happened, then the projector has a cooling or ventilation problem.Originally posted by marco10The guy I spoke with told me it wasn't the LCD panels that were "burned" but something about the lazer, I didn't quite understand him because he wasn't the technician. Anyway they repaired it under warranty and all is well.- Bottom
I'm with Kevin. Any chance you misheard "polarizer" as laser? If not, I am guessing he misheard it from the tech.
This is something I can well believe would happen in a defective PJ, say one with the initial UV reflector/filter MISSING, that the first polarizing plate would get a nasty burn.
BB- Bottom
I too believe he was referring to the polariser. Overheating those puppies can do a lot of damage to the image. Wonder if they checked to make sure the fan was operating properly. ALSO HAVE TO KEEP THOSE FILTERS CLEAN.- Bottom
Hi Guys. I called Sanyo and spoke with a tech. this time. The person I talked to before wasn't even a salesman or a tech. Can you believe it was the receptionist???!! Anyway, what was replaced was the LCD Prism Assy. But what I don't know, and neither do they (Sanyo), is what caused it. The Technician I spoke to the second time told me he would give me a call to let me know what the cause could have been. Lazer? That didn't sound right at all.:righton:- Bottom
The optical blocks in newer (everything after the XP21) sanyos are one piece assemblies, individual components are not replaceable, so that replacement included prisms, polarizers, LCD panels and some other stuff.
Let us know if you hear more.
THanks.
BB- Bottom
OK, I've now seen posts from 3 other Z2 owners (on another forum) with burn problems at low hours. Starting to think Sanyo has an issue here.
Any other Z2 owners here see any hint of yellowing anywhere in their image? Put up the plain 'no signal' blue screen and look really closely, should be visible.
BB- Bottom
Originally posted by Brandon BThe optical blocks in newer (everything after the XP21) sanyos are one piece assemblies, individual components are not replaceable, so that replacement included prisms, polarizers, LCD panels and some other stuff.
THanks.
BB
Now, the dust isolation on that kind of system is good, but the servicability is poor- that would be an expensive repair for an owner out of warranty.
Curious to see how this plays out....
~Jonthe AudioWorx
Just ask Mr. Ohm....- Bottom
Change that to OUGHT to be good. My sanyo is probably the WORST, bar none, PJ I have ever seen for dust on the optics that is visible on the screen. The provided filters were absolute crap, the replacements sanyo shipped out within 2 months were semi-mitigated crap. I had to tape 2 large blisters of "evil orange" HVAC register filter material over the existing filter openings to prevent a weekly dust blowout to even use the PJ. And I still have to clean it every few months. Others seem to have a little more luck than I, but my house is not particularly dusty.Originally posted by JonMarshNow, the dust isolation on that kind of system is good, ~Jon
If I now find out they are more susceptible to blue plate issues than most other LCD units, going to have to really look hard at ever considering one of their display products again. At home or at work.
BB- Bottom
I can really understand your concerns, given that experience. Even Sony went through several iterations of filter design in the 1XHT series projectors; especially if they're mounted on ceiling and the filter is then on the top, this seems to be a problem.
~Jonthe AudioWorx
LCD burn can be a problem but is not permanent like CRT's I am an engineering tech for a company that builds LCD projectors for MRi environments. I had an issue several months ago where a static image was left on a PJ for a 2 day burn in. The image was left in the LCD display after the source was changed or disconnected. With a little research, I found that there is roughly a 3:1 time ratio for the burned image to dissappear. So, if your image was burned in for 24 hours, it will take at least 72 hours of use for the image to be removed. After about 6 days of constant use, the PJ mentioned above had a clean image. Polarizers usually made of glass with possibly an overlay and shouldn't aquire any image characteristics. The prisms usually have some sort of optical coating, but shouldn't retain any image as well. If something was "burned" into either of those components due to a heat issue, there would probably be physical damage elsewhere. Just my two cents. Hope it helps.
Robert- Bottom
That's the memory effect, we encounter that a lot too.
What Marco has is an actual burn problem. The organic layer on the one of the polarizer plates actually is ubrned/degraded, typically the blue one, probably by the heat and any residual UV that gets through the filtering, to the point where it is no longer stopping the non-blue portion of the spectrum. You then end up with yelowing of the image. Almost any LCD will do this over a long enough time frame (5000-50,000 hours depending on model).
Marco's unit was clearly made with some defect that caused it to occur almost immediately.
BB- Bottom
by tf1216I have been looking at Samsung rptv's and I can not figure out the difference between all of their 1080p models. Is there a simple answer to my confusion.
Also, why are their LCDs way more expensive than their highly touted dlp screen?
Lastly, why the heck does Best Buy... -
by MitchellThis is probably a worn out topic but I can really use some advice.
We live in an apt in NY and want to put in a small HT system is a room that is 14x8. We would have a couch on one end and want to mount a flat panel TV on th opposite wall. LCD or Plasma is the only question.
The LCD we...-
Channel: Select Manufacturer Clubs
by Briz vegasHi guys
I have a 2 year old Hitachi PJ tx 10 LCD 16X9 projector which has used not much more than a quarter of its lamp life (I watch mostly one, at most two movies a week only).
Recently I have noticed that if I watch the really wide screen - 2.35 :1 movie or a 4:3 movie... -
by MitchellI just came back from looking at tvs at J&R Music in NYC. I was looking for at the Sharp 37 and 42" LCD which are pricey and the salesman suggested looking at plasmas. He said that the Plasma Burn-in issue was largely solved using tech. nology that rotated pixels, put grey bars on the sides... -
by Dean McManisI figured that I'd be holding off on HT purchases for a while until I saw some of the black friday prices on LCD displays.
I got up at 6AM on Friday morning expecting that nobody would be out that early (OK I'm new to black friday shopping) and I saw that there were hundreds of people... - Loading...
- No more items.
