Hello all! I'm having an issue with the display from my dvd player not fitting in the screen. Here's what I have. First, my television is the Samsung TXN 3075 WHF(16:9; 30" screen). Secondly, my dvd player is the Pioneer DV-563a.
The top and bottom of the picture is fine, but the both sides are cut off by about 1/2" on each side. I have the DVD player set to for my widescreen television. It is connected via component hookups.
I also used the Avia test disc and THX optimizer mode on one of my DVD's. One example is the THX test where you have a circle inside of 2 rectangular boxes. The circle is round like it should be, the inside box is correct, the outside box just has top and bottom lines.
I have tried 3 different DVD players so I'm doubting that is the problem. I think I might have something setup wrong. The tv is only about 2.5 months old, could there be something wrong with it? Any advice would help.
Shane
Shane
