LCD afterimage (burn in)
  • Glen
    • Dec 2003
    • 867
    Anyone ever hear of this before.
    I took this from the Panasonic PTAE500 owners manual on their web site :
    * Liquid crystal panel
    Do not project the same image for long periods of time, as this may remain as an afterimage on the liquid crystal panel. *
    I have never come accross a statement like this before. Everything I've ever read states that the main benefit of LCD (and DLP) is no burn in ( as apposed to CRT displays ).
  • Bent
    • Sep 2003
    • 1573
    Glen, I think there is less burn in, not no burn in with LCD's.
    I have a buddy with (used to have) a Sony VPL 400Q, that he bought used, it had considerable "4:3" wear on it's panels, but he was able to "excercise" it out by using it in wide mode.
    • Dean McManis
      • May 2003
      • 762
      The crucial difference between CRT phospher burn-in and LCD image retention is that a badly burned CRT is a goner, but LCD panels can usually work out the image memory with additional use, and you really have to abuse them in the first place, leaving fixed, high-contrast images on screen for extended periods of time.
      -Dean.
      • Glen
        • Dec 2003
        • 867
        Thanks Bent, Dean
        That makes sense.
        • Brandon B
          • Jun 2001
          • 2189
          And from the world of extremes -
          We install PJs (primarily LCD) in theme parks where they run 14-18 hours a day. We have seen instances where the PJ is showing a static image 40-80% of the time, you get burn-in. We are able to reverse it, but it comes right back with those useage patterns. We have never had a problem with it when using changing imagery, even where it is repeated a lot.
          This should be at the very bottom of the list of concerns when choosing PJ technology IMO.
          BB
            Samsung announces new thin CRT display
            by Andrew Pratt
            source
            Samsung Develops Worlds Slimmest CRT TV
            Monday, July 19 @ 12:15:00 PDT
            With CRT televisions ever die? Not with innovations like the Samsung 'Vixlim' which is touted by Samsung as the world's slimmest CRT television.
            " The new CRT display,...
            20 July 2004, 11:40 Tuesday
          • Dean McManis
            I ordered a Olevia 37" LCD display
            by Dean McManis
            I figured that I'd be holding off on HT purchases for a while until I saw some of the black friday prices on LCD displays.
            I got up at 6AM on Friday morning expecting that nobody would be out that early (OK I'm new to black friday shopping) and I saw that there were hundreds of people...
            26 November 2006, 22:06 Sunday
          • KennyG
            to Liquid Couple...or not to Liquid Couple...that is the question...
            by KennyG
            I have been wondering this for about 2 months...do liquid coupled projectors put out a better picture than air coupled units???
            For those who don't know, LC'ed projectors have fluid between the crt face and the first lense of the lense assembly. This fluid creates a denser environment between...
            14 May 2001, 23:47 Monday
          • perla4u
            Rotel RSX1057 - LCD TV Setup Issue!
            by perla4u
            Hello to this great forum. I have been pondering quite a while reading and learning quite a bit of info here. As always, you get to a point where its very specific to your situation and here I am, requesting all for your help.
            I just bought a Samsung LCD TV (55 LED TV, very slim design...
            06 April 2009, 14:18 Monday
          • Mitchell
            LCD vs Plasma
            by Mitchell
            This is probably a worn out topic but I can really use some advice.
            We live in an apt in NY and want to put in a small HT system is a room that is 14x8. We would have a couch on one end and want to mount a flat panel TV on th opposite wall. LCD or Plasma is the only question.
            The LCD we...
            27 September 2004, 19:51 Monday
