I while ago there were many discussions regarding the implementation of the volume control for the DCX2496. I use the combination of the DEQ2496 and the DCX2496 to realize most the EQ needs of my full range 3-way dipole system. Until now I have been using two motorized 4-gang pots from Alps. The pots, naturally, were placed between the DCX and the power amps. Well, suffice to say I no longer use that scheme.
I wanted to set-up an all-digital signal processing, whereby the signal stays in the digital domain from the source such as the CD or DVD player to the power amps. That should include all the EQ and, yes, the volume control as well. The D/A conversion is to take place immediately before the Power Amps. I now have this system working and the key to this set-up is a pro-audio box from Roland, the M-1000 model. It is no longer manufactured but there are many floating around on the net and some are new. I bought two of them and it should say that I am highly impressed with its capabilities.
The M-1000 is a digital mixer with 5 digital SPDI/F inputs including one Toslink and internal 24-bit 96 kHz processing. That means that it up-samples everything to those numbers. It also has digital volume control!
Many will say that it is a problem because you would lose resolution to the tune of 1 bit for every 6 dB of attenuation. Well while it is true in principle I do not think it applies here. Here is why, - the CD data is 16 bits and when this Roland box turns it into the 24 bit word, it simple does it by shifting the 16 bits. So, no new data is created and no benefits of S/N either, but now you have 24 bits to deal with. The extra 8 bits represent slightly more then 48 dB of usable attenuation. That means that the Roland M-1000 can give you a 48 dB of attenuation before you start chopping the resolution that really matters, - the 16 bits of original data.
Naturally enthused with this new-found reality I did, what I always do with all my new toys, - I riped the cover off and looked inside to see what makes it tick and if I could make it tick a little better, - you know what I mean... I was pleasantly surprised to find Analog Devices AD1895 Asynchcronouse Sample Rate Converters (ASRC), - 4 of them. What does it mean? It means that we have a near complete immunity from jitter related distortion and also the processing to the tune of 125 dB of S/N. That's 20 bits! Analog circuitry notwithstanding since we do not go there, but it was also well done. By the way I am already thinking about replacing those AD1895 with AD1896! I need to take my pill now...
Well, in the end here is what I have now, - the DVD player outputs AC-3 or DTS SPDI/F signal into Technics AC-500 processor. I modified the AC-500 so that now it has 3 SPDI/F outputs for the 5.1 channel sound. It was really simple and it lends itself nicely to such modification with about $50 in parts. I take both front and rear channel in the digital SPDI/F form and input them into two Rolland M-1000 units, - one for the front and one for the rear. The M-1000 controls the volume and the balance. From M-1000 I take the signals in digital SPDI/F form and input them into the DEQ-DCX combination for front and the DCX in the rear. So far all processing is done in the digital domain with no resolution loss. The DCX does the requisite D/A conversion and the final few dB of level adjustment for the high-mid-woofer set-up and outputs six analog signals to the power amps.
Well, the listening test support the reasoning, - I like what I hear. The Roland M-1000 becomes a 5-input fully digital pre-amp with volume and balance control. It is ready for 24 bit sources when they come to market and works with no resolution loss for 16-bit sources. Since the maximum digital volume level at the time of recording is 0 dB the combination of M-1000 and the DCX cannot be overloaded into clipping, - which also nice.
Also if one were to use an additional resistor divider built into cables at the output of the DCX, then an overall level adjustment done by M-1000 can be constraned to at most 6 db, - which 1 bit of resolution loss. Therefore, if and when the 24-bit sources come to market, the M-1000 will still be a great unit to use. Becouse 1-bit resolution loss cannot be ever heard by humans, let alone passed through the noise of the best analog power supply available.
Al in all I am happy. And now I can address my project du jur, - the subwoofer, - for which I do need help! But that is a topic for another thread.
Regards to all,
Victor
Regards to all,
Victor
