I have a rear projection LCD and DirecTV HD receiver. I run video from the receiver to TV using component video cable, which is on Component 1 on the TV. When I switch channels, the channel comes on, then the TV screen goes black and shows "Component 1". Then the channel comes back on. Does anyone have any idea why this happens. It's not a big deal, but it's very annoying. Any help would be appreciated.
Problem switching channels
Can you try another tv with that receiver just to see if the box is working?
Does the LCD work with any other source?
Have you changed any settings in the menu/s?
Check to make sure the video is assigned properly.CLIVE
HEY!! Why buy movie tickets when you can own a Theater?- Bottom
is your direct TV remote also set up to do things on your TV? Some times if you have TV selected on your direct remote it messes things up. Me and my wife have dish. In our bedroom we some times forget to select "sat" on the dish remote, and crazy things happen.
I would check what uncle says first though.
welcome to the Guide!
:welcome:The Bitterness of poor quality last longer than the joy of low prices.- Bottom
Its your box, I had a box similar to that from Comcast, it was like a delay, replaced it with a PVR box, no more issue. I noticed it only did it with components, if I hooked it up via coax it worked fine. I think its the internal design of the unit.- Bottom
by perla4uHello to this great forum. I have been pondering quite a while reading and learning quite a bit of info here. As always, you get to a point where its very specific to your situation and here I am, requesting all for your help.
I just bought a Samsung LCD TV (55 LED TV, very slim design...-
Channel: Club Rotel
by greggzNorth Reading, MA—January 2007—Rotel, well-known throughout the world as an affordable high-end manufacturer of components for music and home-theater audio-video systems, has introduced the RVE-1060, 1080i video scaler, which seamlessly brings together analog and digital video sources.
Channel: Club Rotel
by LexGentlemen, start your engines. Your Dolby Digital and DTS engines that is.
Tonight, I just opened the first of my new CVDT (Custom Video and Digital Transmission) branch, with the introduction of Twisted Kitties and Soft Kitties Silver Laced Digital Interconnects. I dare you to compare quality and...
by SteveGAs some of you may know from my previous posts, Immersive, Inc., has introduced a PCI video processor card featuring Faroudja’s patented DCDi processing. The HOLO3DGRAPH is designed to accept Serial Digital Interface (SDI), Component, S-Video, and Composite video inputs. It combines with your PC graphics... -
by zgeistFirst, I'm new to this HT thing - I *have* read lots of posts, but I'm still confused - so I thought I just ask. Second, I'm posting this in Club Rotel because one of the options I'm considering is the RSX-1055...
Basically, I'm getting a plasma tv and I'm trying to figure out how best...-
Channel: Club Rotel
- Loading...
- No more items.
