Signal loss using coupler?
  • deanlnh
    • 3
    I setup my 4805 this weekend and the 4m composite cable I bought was a little too short for my ceiling mount. Because this is the longest cable they sell in my local stores I bought some couplers and used the 3 foot cable the projector came with. My question is how signal is lost by using a coupler vs. buying a new longer cable?
    Thank you.
  • George Bellefontaine
    • Jan 2001
    • 7636
    I'm no expert on cables but I doubt if you'd see any signal loss on composite with a coupler. Is there a reason you are using composite ? This is not the best connection for your projector.Componet is best for picture quality and S-Video second.
    My Homepage!
    • deanlnh
      • 3
      Thanks George, Sorry, I am using the component cable. I couldn't see why I would lose a lot of signal either. The sales guy at Tweeter etc. said I would have significant loss, then tried to sell me a $250 cable that was long enough.
      • Kevin P
        • 10812
        As long as the coupler and cable (connectors) are of decent quality you should see little, if any, signal degradation. A cheap coupler or cable connectors or dirty connections cause more degradation than the use of a coupler in the first place.
        The guy at Tweeter just wanted to sell you an overpriced cable.
        • ekkoville
          • 392
          I'll bet it was a "M****** Cable"!!!
          ____________________
          Erik
          Just another case of the man trying to keep us down! :B
          • deanlnh
            • 3
            Thanks for all the answers, and yes it was an M****** cable he was trying to sell me.
            P.S. From Bedford, NH and a Yankee logo?
            • ekkoville
              • 392
              I know it looks bad.....born and raised NY. Can't shed the roots, you know. Bills fan also...but do root for Pats.
              Erik
              • Clive
                Home Theater Glossary
                by Clive
                G'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
                I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...
                11 July 2005, 22:38 Monday
              • lancef
                periodic loss of HD signal OTA
                by lancef
                When recieving HD signals over the air I get an occasional loss of signal for 2 or 3 seconds and the screen goes blank. Any ideas as to why I lose the signal. I have a 50 IN SONY LCD with an 80 in boom/32 element antenna roof mounted. I am roughly 28 to 30 miles from transmisson tower.
                29 January 2007, 09:14 Monday
              • CPALIU
                RSX 1057 & Charter HD Cable Box 3500HD problem
                by CPALIU
                I'm running into a problem with my Rotel RSX 1057 & Charter HD cable box (3500HD). I have the cable boxed hooked up to the RSX-1057 using component cables to Component in 2. When I select video 2, I get the cable signal just fine from the cable box. Howeve,r when I push the menu option on the...
                18 August 2006, 11:31 Friday
              • porkie
                co-ax cable to s-video
                by porkie
                I have a panny 900 and am looking for a way to plug in my regular co-ax cable signal into my panny to watch some of the plympics is there a comverter to switch it to s-video. thanks
                17 February 2006, 14:57 Friday
              • P-Dub
                Pioneer 450H-S HDD/DVD recorder review
                by P-Dub
                I thought I would write a quick review of my exeprience with this unit. By no means is will this cover everything, but if there are any questions on how the unit functions, please don't hesitate to post here and I will try to find out.
                My main reason for...
                23 July 2007, 15:00 Monday
