Hello. I just got my RSP-1098. Firmware is version 3.1 (I guess the 2 week wait was worth it... seems as if I ended up with the most recent version). I just got my Classe CAM-200 for the center channel yesterday.
Setup:
Left, Center, Right - CAM-200
Rear - RB-1080
The gain as tested by Stereophile is about 28.4 dB on the 1080... and about 29 dB on the CAM-200's. Therefore, I would expect little to no difference in setting up the volumes. I use to have an RSP-1066. The sensititives of my speakers are all rated at 89dB except the center, which is rated at 90dB. I have found that the fronts are probably a bit higher than 89dB and the center is probably a bit lower than 90dB... because if I reduce the center by 1dB, it sounds a bit softer and if I leave it as is, it's a bit louder... so I just leave it as is ... helps a bit with dialog so it's all good. As for the rears, I have found in the past I needed to boost it up 1dB to match it with the rest due to the drivers not pointing as DIRECTLY to me as the fronts.. so you get that natural 1-2dB rolloff as you go off axis... I actually had it set 2dB higher so it was a bit louder than the fronts by about 0.5dB (just a preference thing).
Ok, now with the 1098... I had to pump up the rears 7dB just to get them to match the center and mains... is something wrong? Even with the 1066 and CAM-200's as mains, I did not have to do this...
I looked at the sensitivities of the 2 amps... 1.5V for max output for the 1080... and 1.0 V for max output for the CAM-200... but I thought it was the gain spec that determined loudness?
To me, having to adjust more than 1-3 dB seems a bit odd.
Also, on the 1066, I use to use 67-70 (max reference level) volume for 2 ch listening, 68-70 for DTS, and 73-75 for Dolby Digital. For the 1098, I am finding I'm using 80 for DTS, 85 for Dolby Digital, and about 75 for 2 channel. Is this mostly due to the 1098 volume settings being configured a bit different than the 1066?
Setup:
Rear - RB-1080
