rsx1065 owner needs help
  • koshko
    • Feb 2003
    I am the owner of the 1065 ver1.1. I am curious what is involved in the firmware upgrade ie what do I need to accomplish this? Also I was reading on this site that the upgrade from v1.2 to v1.3 required an EPROM change. What is involved in an EPROM change? Is it just a firmware upgrade or do I need to have something physically upgraded on the computer.
    These questions may sound trivial but I have no idea on how to go about upgrading my 1065. I would like to take adnvantage of the DTSneo:6 and DDex features.
    One other questions were do I get my hands on the firmware or patch cords that I will need.
    Thanks for all the input ahead of time.
  • ssmith77
    New owner
    by ssmith77
    Hi everybody new to this forum and just took the plunge and got my first Rotel setup
    RSP 1098
    RB 1090
    RMB 1095
    I spent all last night upgrading in the 1098 EPROM and firmware as had a problem with the com port communicating to the 1098. Finally after about 3 hours I figured...
    11 June 2004, 17:26 Friday
  • Robodell
    RSX-1065 firmware
    by Robodell
    Hello - I'm new here... just picked up an RSX-1065 this weekend. I am running with PolkAudio LSi15 and love it!
    I do have one concern: I noticed that the firmware is 1.5.1_020702. The Rotel site says that I should upgrade to 1.57, although I noticed that there is a 2.xx numbering scheme...
    13 August 2003, 22:00 Wednesday
  • thor
    RSX-1065 actual firmware ?
    by thor
    Hi my dear collagues :-)
    i got a lil question about the RSX-1065 - can anyone tell me the actual firmware release number for this receiver ? is it still 1.57 ?
    How to find out on the receiver ? anything wrong if it is a 2.24 ? or is this a "old" machine only upgraded...
    16 February 2004, 19:36 Monday
    Firmware revision documention
    by Andrew Pratt
    Guess what Rotel sent me this morning!
    Note that the HD units indicates the newer models running the modified chipsets. If your machine is using these different chipsets please do not flash your firmware unless you've obtained the correct file directly from Rotel.
    RSP 1066 Software...
    30 October 2002, 13:14 Wednesday
  • Snatchfrigit
    Help with RSX 1065 / RDV 1060 / RB03
    by Snatchfrigit
    I have a few problems with my set-up...............
    Some of the pixels on the display of the RSX1065 are dull, this is the 3rd display in this unit and they have all gone the same way. Has anyone had the same problem? The RDV1060 sometimes misses a few seconds at the start of a track when playing...
    22 January 2006, 18:25 Sunday
