Hello!
Firmware 2.20 if anyone interested to upgrade.
2.18 -> 2.19
only a small display issue (no PrLogic Icon when playing 2CH PCM source)
2.19 -> 2.20
1 PCM2CH, 176K/192K support. When it is 176.4/192K, Temporary G.Delay, Tone can't be controlled
2. Debugging backup error
3. Component error
4. Dolby request, During the 6.1/7.1 settings, use Dolby Pro Logic indication
Be really carefull with the upgrade.
To upgrade the main flash firmware to the current V2.2.0 the DSP EEPROM should be upgraded to V3.4. If you already have upgraded the DSP EEPROM to V3.4 then it is only the main flash software that should be upgraded.
Details how to upgrade EPROM ist available on the Rotel website. However, it's not as easy as main firmware update. A EPROM Flash tool has to be installed on the computer, to be configured and then the EPROM software to be uploaded via this tool. All necessary elements are availbale from the Rotel Webiste (flash tool, firmware and instruction manual in english). If you fail to do this upgrade, hardware has to be changed and cost may be involved.
Regards
Yves
2.18 -> 2.19
2.19 -> 2.20
3. Component error
Regards
Yves
