Connection help
  • deke
    • 107
    Connection help
    Kevin, thanks for the update on CES.
    Does anyone have an idea how I can connect a coaxial cable (like cable / sattelite) to my preamp / receiver? Do I need to get a RF demodulator?
  • Kevin D
    • 4601
    You're going to need some form of tuner to decode the signal. Either a VCR/cable box for cable or an appropriate DSS box for satellite.
    An RF demodulator is used for converting older Dolby-Digital signals out of laserdisc players to standard Dolby signals.
    Kevin D.
    • deke
      • 107
      Thanks, Kevin.
      • sanaka
        video over UTP/cat5 cable
        by sanaka
        Hi.
        I'm building a new house and plan to run in-wall wiring to a projector location.
        I found some cool RCA and S-Video modular wall jacks that terminate via 110 punchdown blocks. The idea being to directly run these signals on Cat cable.
        But will this really...
        01 February 2006, 07:28 Wednesday
      • madmac
        Analog out cable for PS3
        by madmac
        Hey all,
        Have you ever ordered something on line and get something somewhat different than ordered when delivered?. I want to use my headphones via my headphone amp to listen to BD and DVD movies and since my Rotel does not pass digital signals to it's analog out's, I was forced to buy...
        02 March 2013, 07:39 Saturday
      • chinets
        Kevin D and Kevin P question!! SACD on Rotel 1098 Via Digital??
        by chinets
        This is a typical Kevin D and Kevin P type of question as they are great at answering these type of questions. :T
        If I play an SACD in a sony DVD palyer and the light goes on the SONY and states that I am transmitting SACD signal ,and it is connected to a Rotel Pre/Pro 1098 In Digital optical...
        31 May 2006, 05:29 Wednesday
      • Clive
        Home Theater Glossary
        by Clive
        G'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
        I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...
        11 July 2005, 22:38 Monday
      • KRC
        directional HDMI cable
        by KRC
        As with alot of interconnects and speaker cables say they are directional (ie follow the arrows), would an HDMI cable also be directional.
        By adding one of those couplers to an HDMI cable (DVI to HDMI/HDMI), does it take away from the quality of the sound. I was told in the past that...
        01 January 2008, 16:26 Tuesday
