RR-1060 and a switch problem...
  • landshark99
    • 9
    Hello all!
    Glad to have finally purchased a RSX-1057 and loving it, love the remote too but having some problems switching inputs with the RR-1060... sometimes it will work.. other times it won't... i can't seem to find any help regarding a specific resolution and just wanted to see if someone can steer me in the right direction on how to make it switch instead of beeping like a geiger counter... yes yes i know how to disable the beep
    Everything else seems to work like a charm, programmed a couple of remotes no problem, Except the Directv one... but not a big deal for now...
    Any help appreciated!
  • Kevin D
    • 4601
    Sorry if you know this, but you have to hold the input buttons down for a second or two for it to send the code out.
    If you knew that, you can try doing a factory reload on the remote. If that doesn't work I quick call to your dealer should get you a new one coming.
    Kevin D.
    • landshark99
      • 9
      Ya i hold a button down and it beeps like crazy but 90% of the time no switch. I have already did a reset a few times... still no go... I guess will call the dealer tomorrow and see what they say, its only 2 weeks old thanks!
      • soundhound
        • Mar 2004
        • 816
        Try new batteries, you may be pleasantly surprised.
        • Cushie
          RX-1050 Power Switch problem
          by Cushie
          Hi all. I'm having an annoying problem with the AC power switch on my RX-1050. It's a spring-loaded push button, and occassionally doesn't lock in the 'on' position. If I hold the button in all works fine - I hear the power supply relay fire, and then the speaker relay - but let it go and it pops right...
          29 December 2004, 13:08 Wednesday
        • randal
          Looking for long neck PDT SWITCH
          by randal
          Hi All,
          Any suggestion where I can buy the 3PDT switch with long neck
          As you know this monitor statement (yeah ... I know, i hold this project too long) using 3/4 inch of MDF. All of the HS locally their pdt neck is short
          can some one pls let me know where to get it?...
          22 June 2011, 12:44 Wednesday
        • hired goon
          Audiophile quality line-level switch box, with remote?
          by hired goon
          G'day,
          The line-level inputs on my 2-ch pre-amp are not selectable via remote control.
          So I'm looking for a very high-quality line-level audio switch box, with remote control. The sources will plug into the switch box's inputs, and the switch box output will go to an input...
          20 July 2006, 01:21 Thursday
        • imbeaujp
          HDMI switch with RSP-1098
          by imbeaujp
          Hello !
          I have the RSP-1098 and I want to add a HDMI switch with 4 input and 2 output. Nothing complex here, but I want to integrate that switch with RS-232 so when I switch input on the ROTEL the switch do so.
          Anyone knows how to do that ?
          What product to...
          02 February 2010, 06:51 Tuesday
        • Cotrel
          Dish Receivers on A-B Switch
          by Cotrel
          Has anyone tried setting up 2 dish sat receivers on a "A-B Switch?? I just got the 811 HD Receiver and also have the Dish PVR. I want to be able to switch between the two. Am also having trouble finding a good A-B Switch with single input and two outputs and good separation. Would appreciate hearing...
          08 March 2004, 09:42 Monday
