I hope you guys can help me out here.. I'm not too sure if it's my Rotel that is being a bitch, or if it's my DVD player - A Marantz DV-6600..
Anyways.. Playing cd's.. I want to use the Rotel's 2ch mode for this, but I also want to use my sub when playing 2ch.. I checked the manual, and it says I can switch between processed and analog bypass modes. In analog bypass it won't send a signal to the sub.. But when I press the 2 ch button it only displays "PCM 2CH", no matter how many times I push the button.. Is this analog bypass mode? Or is it processed mode?
The dvd is connected to the Rotel with an optical cable and a HDMI cable.. Settings on the dvd has HDMI audio to "off" and the rest is set to "bitstream".. But there really isn't one for just "cd's".. It's DD, DTS and MPEG formats..
I checked the setup on the Rotel, and the sub is enabled correctly everywhere..
Second problem.. And somewhat touched upon in the first one :-).. I really want to play sound via the HDMI link, but for some reason the Rotel doesn't seem to think the HDMI supplies a bitstream signal, so all I get is Pro-logic 2 and DTS:Neo modes.. It doesn't matter how I set up the dvd player, the Rotel insists on no bitstream signal.. So now I run audio via an optical link.. Any ideas? Yes, HDMI version is 1.1 on the dvd as well..
Any help is much appreciated..
/Jesper
/Jesper
