Profigold Cable Direction pre/power amp
  • bluesfan
    • 26
    Profigold 3000 phono leads have an arrow on them. Any idea what direction it should go from 1068 to 1075?
  • Marcel B
    • 62
    In general the arrow shows the direction of the music, so the arrow should point towards the power amplifier
    Marcel B
    • aphexist
      • Jan 2004
      • 158
      Yeah, otherwise the electrons might "clog up" inside the cable.
      • Marcel B
        • 62
        :B :lol:
        • sbank
          Interconnect cable question.
          by sbank
          Hi all,
          (New to the forum, so not sure if this post is in the proper place.)
          I have some Transparent Link 200 cables that connect my pre/pro to my amp.
          My (silly) question is this, what side does the `bump' go on? Eg, is the bump supposed to be closest to...
          15 June 2004, 11:09 Tuesday
        • jazzzione
          Newbie needs the cable guy help!
          by jazzzione
          Well after spending most of my evenings reading posts on this site I finally made the plunge.
          RSX 1055
          RMB 1075
          Fronts- Nautilus 803s
          Rears - Nautilus 805s
          I have not used all of my budget yet, so I am looking at getting a Nautilus center channel and not sure yet...
          01 September 2003, 10:54 Monday
        • david cro
          Speaker cable for B+W Matrix 802 Series 3, and Rotel seperates.
          by david cro
          I have a pair of B+W Matrix 802 Series3 speaker which are powered by Rotel RSP-1068 pre-amp and Rotel RB-1080 2ch power amp, I'm concidering upgrading the speaker cable (2x4m Bi-Wire) and was hoping someme could guide me in the right direction. I presuming quite a few of you have similar equipment,...
          18 August 2005, 15:03 Thursday
        • saurabh
          Direction of Surround Speakers and other placement
          by saurabh
          hi,
          Pls see my room layout attchd with dimensions. The height of my room is 9.5 ft and I cannot change the layout much except for bringing the TV to the left slightly so that its more in line of sight with the Sofa. I will leave 20%(as suggested by an acoustic engineer) of the total length...
          24 March 2005, 00:57 Thursday
        • Preacher
          A little Direction (noob)
          by Preacher
          I'm a piddler and into diy car audio. I've messed with pro stuff, but HT is sort of new to me. I've got a diy HT sub powered by a Crate pro amp. I also have a set of polk M30's for mains and polk cs1 for a center. These are powered with an older technics sa-ax540. My Sony DVD player handles decoding...
          25 July 2007, 14:03 Wednesday
