I have a 1098 and trying to use a Buffalo IR extender with the IR in on the back of the 1098. Using a xantech 3.5mm mono cable from the buffalo to the 1098 and it seems as though the 1098 isn't recieving the IR signal about 70% of the time, it works about 30% of the time - however if I use an IR blaster from the Buffalo to the IR receiver on the front of the 1098 it works 99% of the time. Running an old version of the firmware (1.2) and been too lazy to update - any thoughts??
1098 IR problems
by JudgeBaxterHi guys,
Just a quick ask before I box it all up and ship it back, to see if this has happened to anyone else before.
My RSP-1098 has been working fine out of the box. It's only a few months old (maybe 4 at most), so is onlt just about run in....
I only sit...-
Channel: Club Rotel
by DrBoomWell, it's been almost 2 months now that I've lived with both my Rotel RSP1098 and my Parasound C2 and the time for deciding which I'm going to keep is almost at hand.(not that I HAVE to decide now for some reason, but I'd hate to end up with 2 processors permanently)
I actually own both of them,...-
Channel: Club Halo/Parasound
by kvardasBuilt a delta-sigma DAC/Line Stage as shown below:
The DAC module is the "Buffalo IIISE-DAC", which is based on the ESS Sabre32 Reference (ES9018) DAC chip and accepts direct DSD, I2S and S/PDIF inputs supporting up to 32-bit/192kHz.
A liner power supply...-
Channel: Mission Possible DIY
by OlafDear All,
I have just joined this forum today and this is actually my first message. I am a truly fortunate person having bought the following Rotel setup just two weeks ago
- RSP-1098
- RDV-1060
- RCD-1070
- RB-1080
- RMV-1075
- RLC-1050...-
Channel: Club Rotel
NOTE: 06 April 2020, PROBLEM SOLVED!
Hi!
I'm new to the forum and also to the Rotel brand. I already had one system running with Marantz and another one with the Anthem MRX-500.
Recently I had the opportunity to buy a Rotel RSP-1098 and other equipments from some...-
Channel: Club Rotel
- Loading...
- No more items.
