Help - need weight of N800's and box
  • DM3000 Owner
    • 475
    I need some help. I am buying a pair of S800's and need the weight and total dimensions of the boxes. I would guess that the 800D's are the same.
    Any help is appreciated.
  • arcam_boy
    • 30
    try the b&w website!!
    but I'd say around 150kg for each speaker in a box!
    • akhter
      dimensions of XT2 box
      by akhter
      Does anyone know the box dimension and weight of XT2 box? what about the box of the stands? I am thinking about getting a set from NY as they are not available in Japan, and wondering if I can bring they with me as flight baggage.
      I will be using them as surrounds with N804 mains and...
      14 July 2007, 22:51 Saturday
    • Nateadwg63
      Help with a cutsheet for a subwoofer
      by Nateadwg63
      Howdy all...
      I have a driver selected to build two 10" vented subwoofers. I have the specs for the driver and the manuf. recommended vented box size, but I do not have the proper software that will give me a cutsheet that shows the correct way to cut and where to place the driver...
      05 February 2009, 15:13 Thursday
    • P-Dub
      Upgrade help
      by P-Dub
      Well it's finally time for me to put some serious thought into upgrading. Here's my current system:
      Rec: Yamaha 595
      Speakers: Energy eXL 16 - fronts, eXL C - center, and point 1e for rears.
      Sub: Energy eXLS8, 8" powered sub.
      DVD: Toshiba 3109
      TV: Mitsubishi...
      18 March 2002, 15:55 Monday
    • Grzywa
      B&W 683 and ASW610 MODS (Marble base plates - plinth, SubTrap, add weight on top)
      by Grzywa
      Hi !
      I have few ideas on tuning my speaker setup. I would like to get your opinion on them. Do you think it makes sense? Do you think it may help or not? If some ideas seem to be good for you but there is something you would like to add? This kind of feedback I'm counting on.
      1....
      09 April 2013, 00:13 Tuesday
    • bigchief
      weight of speakers 802D & 803D
      by bigchief
      Does anyome know how much does a pair of 802D and 803D in box weight for shipping purposes, and maybe even box dimension?
      23 March 2010, 09:20 Tuesday
