Question about interconnect cables.
  • ahaik
    • Feb 2007
    • 233
    I hope this is the right place to post.
    Are there different types of RCA cables for Tube Amps and Solid State Amps. Dif impedance etc.
    Asi.
    Nope they are all the same, just the quality of cable is what makes the difference. The better the cable (like Cat for example) will sound a lot better than say your local radioshack cables you'd get.
    • ahaik
      • Feb 2007
      • 233
      Thank you PewterTA,
      That's what I thought. I saw some Chinese dealer on Ebay selling "Tube Amp cables" and I wanted to make sure I can use them.
        • 4157
        Be very careful dealing with "some Chinese dealer on Ebay". You could wind up using nothing but your credit card and Preparation H.......
        Been some sad tales as of late on Audigon.
          That is Sad news, could you elaborate?
          I have purchased two mid level items on Agon, a Rotel RSP-1066 and a Dynalab FM tuner, and was hoping it was place of high trustworthiness, based on my experience and its rep.
          • soundhound
            • Mar 2004
            • 816
            It used to be, but someone left the door open....
              • 4157
              I had read some posts lately about counterfeiters operating out of China and Malaysia. I bought a couple things on Audiogon and had no problems. I would just raise my caution to the level of difficulty involved in pursuing a refund.
              • Club1820
                • 269
                Sad to hear about the 'gon. Over the past year I have purchased several items there including Rotel equip. and M&K Sub. My first attempt at the M&K sub didnt go so well. It arrived inoperable due to shipping damage. Luckily the seller took it back, no problems. 2nd sub, different seller, arrived perfect.
                Nothing but good experiences on the 'gon for me. (knock on wood)
                Rotel 1068, Rotel 1060, Rotel 1055, Rotel 1095, Rotel 956, Rotel RLC-1040, M&K VX-860 Sub, Whatmough M30s, Squeezebox 3
                  Yeah I bought my yammy receiver from Videogon or Audiogon...one of them.
                  • ahaik
                    • Feb 2007
                    • 233
                    I bought my Parasound HCA-1000A there, my brother his Rotel processor and tuner lately, we are both very happy with products
                      • 4157
                      Yup , I've had excellent results from the 'Gon , but I follow basic safety precautions. I avoid any region with a higher than normal number of problems. Lately , that has been Asia.
                        • 27460
                        I see where this thread is headed, and it's not really useful for our site at this time. So, please turn off the customer appreciation/dislikes for auction sites.
                        I for one, vote to support your local dealer on in store dealer only items, support your HTGuide sponsors for other items.
                        If the original poster needs good cables, why not see a pro, namely me. CATCables.com will sell you just what you need, without the hype you don't need.
                        actually, I think this thread has run it's course, if auction discussions continue I will close it. It needs to be on the primary topic only.
                        CATCables.com
                          • 16174
                          Asi.
                          It's a good idea to pay some attention to the cable specifications. The area where you'll see the most sensitivity to variation is for preamp to amp connections with vacuum tube preamps or passive preamps. Why? It's a matter of the output impedance of the source, versus the parallel shunt capacitance of the cable, which forms an RC low pass filter at some corner frequency. This may also be a factor for the output of CD players with vacuum tube buffer stages, which are popular with some audiophiles.
                          Depending on equipment location, the preamp output to power amp run may be longer than other cable runs, which means the influence will be greater (RC network with lower corner frequency). With this type of equipment, braided conductor constructions without a sheild (like the CAT Cables SilverCATs) will probably provide the best performance; the braided conductors reduce common mode pickup substantially, but with minimal cable capacitance.
                          If you use equipment with higher than standard output impedance, the cable capacitance should be a criteria for cable selection. For more conventional solid state gear, with output impedance in the 22-100 ohm range, cable capacitance, unless it's unusually high, shouldn't impact performance.
                          ~Jon
                            • 27460
                            Excellent post Jon. I will also add that twisted pair reputedly does have a lower capacitance than a non twisted pair cable, which possibly explains one reason Kingcats have been so well received due to their twisted pair topology because most of my patients, I mean customers do have solid state electronics now. Jon may confirm or deny that, I do consider him the true electronics expert here, not me. :-) I just know a little about cables.
                              • 4157
                              [QUOTE]I just know a little about cables.[QUOTE]
                              ROFL. Yeah , Doug picked up a couple bits on cable construction along the way! Have to agree with his previous post. You will probably never get your money's worth from "some Chinese dealer". Talk to Doug. He has many very happy customers around here. We don't hang around for the free beer!
                              • Club1820
                                • 269
                                Free Beer?!?!? Where? Did I miss something?
                                • Russ L
                                  • 544
                                  Not Chinese beer I hope.:nonod: You'll only try it once! 8O -Russ
                                  Russ
                                  • Club1820
                                    • 269
                                    Tsingtao Beer, actually pretty good.
                                      Really? I'm not a fan. Found it skunky.
                                        • 4157
                                        In the last few years I've found several "imported" beers are now "brewed under license" in Canada. Nothing against our friendly neighbors to the north , but now Foster's , Tsingtao , and Sapporo all taste like Molson's. :blink:
                                        Now , before a roving band of patriotic Canucks comes down here to drown me in a vat of LaBatt's , I have nothing against Molson's beer. I just don't want my $8 six-pack of Sapporo to taste like it.
                                          Asahi is a Japanese beer that you might like if you enjoyed Sapporo.
                                          Some beers I tried when in Korea are Hite, Cass and OB that also have a dry clean finish and are worth at least a try.
                                          • Russ L
                                            • 544
                                            I'm not a big fan of Labatt's and only like Molson's Dry. Its a shame if Sapporo now tastes like Molson's . Had it over 10 yrs ago before it started tasting like Molson's Canadian? (shudder) and it was a great beer. We still know how to correctly make Toyota's up here tho -Russ
                                            (Hmmmm, 8 beer posts in a row. This thread may get relabeled.)
                                            Russ
                                              • 4157
                                              I like Asahi very much. As for being drowned in a vat....
                                              A brewer fell in a vat of Guinness and drowned. His supervisor called the man's wife and said "I'm afraid there's been an accident here at the brewery-your husband fell in a vat of Guinness and drowned". The wife replied "Aye! The poor soul didn't suffer much , did he? Pray , was it a quick death?"
                                              The brewmaster replied " I'm afraid not , ma'am. He got out three times to pee".
                                                When I'm comparing RCA cables for Tube Amps and Solid State Amps I find that the very best beer in the world to drink is Steinlager.
                                                • Russ L
                                                  • 544
                                                  If thats the case(pun intended) then maybe Steinlager would come on as a sponsor of HTGuide :W -Russ
                                                  Russ
                                                    I'll drink to that.
                                                    Now if we could just get a single malt producer to be a sponsor!
                                                      I'll drink to that.
                                                      Will this one do?
                                                        • 27460
                                                        Lee, good one!
                                                        • snowball
                                                          difference between S/P DIF cables and Fibre Optic cables??
                                                          by snowball
                                                          What is the difference between S/P DIF cables and Fibre Optic cables??
                                                          i must add that i know absolutely nothing about canbles,so any help and tips on wires and what to look for when searching for them will be greatly apreciated!
                                                          18 March 2006, 03:55 Saturday
                                                        • Rick Hunter
                                                          Interconnect help!
                                                          by Rick Hunter
                                                          This is a newbie question for sure but I'm looking for a good solid answer all the same. I have a 7.1 channel pre/pro. I have a 5 channel power amp along with 2 mono blocks. I know, ..... well at least I'm pretty sure, that I am supposed to use three "red" colored interconnects for my FR,...
                                                          20 July 2010, 00:09 Tuesday
                                                        • Johnny_Jo
                                                          Which Interconnect Cables
                                                          by Johnny_Jo
                                                          Hi all,
                                                          I have an Yamaha RX-V 4600 and i'm planing to buy a Rotel RMB-1095. My speakers are Dali Concept 10 for front, Dali Concept 8 for suround and an Yamaha YST-1500 for sub.
                                                          Can you recoment me any good type of interconnect cables ?
                                                          (Most of my cables are Van den Hul). Any suggestion...
                                                          23 October 2006, 04:23 Monday
                                                        • KRC
                                                          subwoofer interconnect
                                                          by KRC
                                                          Do any of you use special subwoofer interconnect cables or just regular interconnect for your B&W sub.
                                                          07 December 2006, 20:56 Thursday
                                                          Sonic differences in Interconnect fact or fiction?
                                                          by Andrew Pratt
                                                          This topic often gets the geekers and tweakers all fired up hotly debating the merrits of both sides and inteligent debate can be fun and a learning process for both sides. My point with this post though is to tell you what I've discovered twice now with my IXOS interconnects. Several moons ago I was...
                                                          19 January 2001, 10:56 Friday
