What are the true power needs of the average person, and how are companies meeting it?
From this link, I've seen that actual Watts measured can be different from advertised Watts.
And today I was checking out this FAQ at a classic Marantz site, and about half way down I see the question "Why does a 35 watt Marantz sound better and louder than many 100 watt receivers?"
The answer got me thinking about power conversion. My lowly Yamaha is rated at 350W, 70Wx5, but the normal power consumption of the unit is only 280W, much less than 350W. A Max power consumption is listed at 650W. So it could concivably put out 350W in an instant. So I would get a power conversion factor of 0.538 = 350W/650W. But what was interesting is if I use the conversion factor against the normal power consumption, I get about 150W or 30Wx5, 280W x .538 = 150.
Hmm, that's not a lot of power. However, checking out this link, it seems that for normal listening levels with medium efficient speakers, you need less than 5W. It's the peaks that require the power.
So this power thing seems to have gotten out of hand, I don't doubt more power is better, but what about more real power? Just for fun I looked at the Outlaw750 amp. It's rated at 165X5, or 825W. It has one number that has Max power consumption of 1,800 watts. So 825/1800 = .458. This makes me wonder about the effeiciency of my lowly Yamaha, can it be so good as to convert .538 vs a dedicated amp that can only convert .458?
I think that the war of higher numbers will continue. I just wish I could jump in and buy more gear.
Paul
Paul
