Bi-amping vs. more watts/channel
  • robo
    • Mar 2001
    I was wondering what anyones opinion might be on bi-amping compared to more watts per channel. I have a B&K AVR202 combined with Energy Connoseiur C6 fronts. Currently, I have the mains bi-wired and was wondering if I would notice an inprovement if I was to swithch to bi-amping or adding an amp with more watts per channel. The B&K is listed at 105 watts/channel. If I was to bi-amp, I was thinking around 100 - 125 watts per channel. If I go the other route, I was thinking something in the neighborhood of 200 watts/ channel. Any advice/opinions would be greatly appreciated.
    Rob
  • Lexman
    • Jun 2000
    • 1776
    Robo, here's my take on it. Also welcome to the forum, I know you just signed on this week.
    The advantages of passive bi-amping. (meaning the internal crossovers are not disconnected.)
    1. Should have better dynamics at reference levels. Why? Well, if the units are built to the same quality, the seperate amp approach should have more reserve power supply.
    2. Perhaps minor difference in speaker imaging.
    Adavantages of 1 amp.
    1. Takes up less real estate.
    2. Less cables involved and electric plugs.
    3. Perhaps less cost.
    4. Won't loose much over method 1.
    Best method for great results with bi-amping, you need to active bi-amp or tri-amp. This means you have to seperate internal speaker crossovers for 2 way bi-amping or the 3 way crossovers for tri-amping.
    To trade speakers, you likely have to go back in and reconnect crossovers. Might be a little tricky. This will require more cabling as well as External crossovers to seperate your signal into the 2/3 individual highs/mids/lows. Major bucks.
    Results? Increased imaging and detail, plain and simple, as well as the dynamics for reference levels. Bottom line? The differences will be small. But when most people get to this level, they are looking for that last little bit of quality in their system. Or like Jon, just love to tweak this stuff like he does computers. lol.
    Hope this helps,
    Lex
    • KennyG
      • Sep 2000
      • 746
      Let me add a couple twists to Lex's thoughts (I'm more twisted anyway)
      First if you are planning to bi-amp the best way to do it bypassing the speakers internal crossovers. You'd come out of the preamp, into an electronic crossover, from that to your amps, and from that the low end amp goes directly to your woofer (better coupling means better control) The mid-high freq amp goes to an upper crossover, if it's a two way speaker, directly to the tweeter...again better control over the driver, although tweeters and midrange drivers are easily controlled.
      If your lucky enough to tri-amp a three way speaker you would run each amp directly to each speaker.
      If I were choosing between bi-amping or a single bigger amp...I'd go with the bigger amp. Bi-amping is nice, and it will sound marginally better, however there is no substitute for power, bass is deeper and better defined (read controlled here) the overall presentation is more powerful and, with a quality amp, cleaner.
      There is no substitute for horsepower...Kenny
      • moonlightdrive21
        Biamping with the 802D's
        by moonlightdrive21
        Has anyone tried doing A/B comparisons on the 802D's with biamping vs. not biamping?
        I was wondering how much better it would sound with two Classe 3200 power amps (200 watts per channel) biamped on my 802D's/HTM2D as opposed to just using one 3200 amp for the three speakers.
        03 July 2008, 11:16 Thursday
      • mtlrx
        Biamping the HTM2D?
        by mtlrx
        Hi everyone, first post. I am wondering if it's worth biamping the HTM2d. I will be getting 802d and want to biamp them with Bryston 6b(3 channel) 300w/channel amps but wondering if it's worth biamping the HTM2D. If I do biamp the HTM2D I will get another 6b or should I just get a 4b(2 channel) also...
        31 May 2006, 21:10 Wednesday
        250 watts Bi-amp VS 400 watts Bi-wire?
        by Race Car Driver
        A question thats been lingering....
        Now, say you had a pair of speakers, with bi wire posts.
        Now heres two scenarios.
        1)Take those speakers and hook them up to...
        *Each speaker gets a mono block, bi-wired, rated at 400watts RMS 8 ohms
        (400...
        16 December 2005, 20:46 Friday
      • johnADA
        New Crossovers????
        by johnADA
        Newbie here and hello to all.
        You all have been blamed for what I'm going to post next, well thats what I told the wife when she asked, WHY ARE YOU DOING THIS to new speakers!!!
        Well I said I read these forums and!!!!
        New to DIY, but not totally a newbie...
        30 December 2006, 10:39 Saturday
      • Taco
        1095 w/ 1080 biamping 802's?
        by Taco
        I'm looking into adding a 1080 (2x200watts) to my 1066 preamp and 1095 (5x200watts). My thought is to biamp with the 1095 LR and the 2 channel 1080 running to each 802 so that each 802 is getting 400 watts. Does this make sense or is there a better suggestion out there.
        Thanks for all...
        16 June 2003, 22:12 Monday
