Profiles
Tags: None
That's a good point Andrew. Also,I added a hobbies and outside interests field so that we could all get to know a little more about each other. Please fill it in if you like.
Lex
<A HREF="http://www.catcables.com" <IMG SRC="http://www.htguide.com/lexman/other/sm_logo.gif"- Bottom
Updated the equipment and added a link to my HT info (well it's a little out of date, missing the maggie 1.6's)
- Wes
My Home Theater- Bottom
by LudvigCan someone sort out the benefits/drawbacks of different cone curve profiles? Datasheets talking about straight, exponential, curve linear profiles and so on tells me nothing.-
Channel: Mission Possible DIY
by aud19I've got a NEC MultiSync FP955 monitor at work that seems to only have 9300k colour profiles available (I tried their web page and even their telephone tech-service :? ). I'm wondering if anyone knows where I could find a nice 6500k icc/icm colour profile from? Should I just use the standard "SRGB"...26 March 2004, 14:40 Friday -
by CADman_ksOK... Been lurking around, on and off, for a while (over a year), and finally joined. GREAT SITE!!!
There's just so much GREAT information out there, that it just about makes a guys head hurt!!
A lot of the information out there is for filling up "normal" sized rooms,...
by greg77543I'm building a pair of kit sealed box LS3/5a clone speakers. The kit is supplied with egg crate foam for interior walls. I thought sealed box speakers all needed loose poly fill of some sort. Should I use egg crate foam, loose poly fill, or both? And if poly fill is needed, what type/brand do you recommend,...-
by Eric JHi.
I've just completed the bulk of my first DIY woofer. I used the Dayton 8" DVC and the Dayton 70 watt plate amp. Box was built using 3/4" MDF with a volume of .508 cf.
My question is regarding stuffing and bracing. I've noticed that this tiny little system weighs...-
- Loading...
- No more items.
