Line level sub connection - mono?
  • rcchap
    • Jan 2004
    • 49
    Looking to hook my sub up via the line level pre outs (front speaker) of my reveiver. I've got a typical sub wire that has a t-type splitter on one end. Would it work connecting the front L and R speaker preouts to a single line in on the sub or should it be reversed. My inclination is the first choice. I think I remember reading that the sub processes everthing to mono internally anyway.
  • theMaximus
    • 179
    I'm curious as to why you are having to do this. Does your receiver not have a subwoofer output? Connecting the sub as you described would work only if your subwoofer has a active crossover that cuts out the high frequency signals (typically over 80~100 Hz). Also, make sure to cut out the low frequency signals going to the front channels using the receiver settings.
    Victory Shall Be Mine!!! :heh:
      • 27460
      Though I have never tried this, I don't believe the signal can be blended from 2 to 1 without electronics designed to combine the signal.
      Lex
      • rcchap
        • Jan 2004
        • 49
        My sub does have a variable active crossover.
        I cannot adjust crossover settings with my receiver.
        My receiver does have a sub out but I am afraid that there might be some issues with the two low pass filters (receiver and sub) working together.
        • hidefdvd
          • 60
          What sub are you using? You should run your sub coax cable from the receiver to the subs LFE input. If you have a L/R LFE input then use the splitter to run into both. This gives you either a 3db or 6db gain. On the back of your sub set the crossover to its highest reading and set your speakers in your sub to small. Your receiver? may have a fixed crossover when the speakers are set too small(100 or 80hz) So by setting your subs crossover to the highest setting you won't get any issues.
          • rcchap
            • Jan 2004
            • 49
            I would rather bypass the LPF in my receiver and use the one in sub. Why use a pre filtered signal? I cannot defeat the LPF in the receivers sub out so I was wanting to use the Speaker line out with the front speakers set to large and all others set to small with sub set to OFF. I like the sound of my front speakers as large. Just seems to be fuller, more even stage. I believe that this setup will help but I am wondering if I can get away with using one cable from the receiver's R/L speaker preouts (line level) to the subs line level in or should I use two cables (R/L)?
            Or am I just crazy :roll:
            • junior77blue
              • 635
              Use 2 cables...otherwise you will only be sending the sub a R or L channel signal which isn't the FULL MONO signal.
              So, from the reciever R/L preout have a 1Male=>2Female RCA one going to your stereo amplifier the other going to the input of the subwoofer.
              I don't think you will notice a difference in sound if you were to use the reciever crossover and the subwoofer crossover simultaneously, assuming one was much higher than the other....but who knows.
              • rcchap
                • Jan 2004
                • 49
                Thanks Junior, I have the tweaking bug. I just recently moved my system to a new room and the sound is a little off. It probably has more to do with the room and my speaker placement but I can't help trying any little thing that I can think of without spending any more $$.
                I have read that when both LP filters are combined, whatever their settings might be, that the interaction can cause irregularities in the frequency response.
                I don't have a separate amp so my preouts on my receiver are all open.
                Do I need one cable coming from my receiver front L line level out to the subs L line in and another cable conecting the R line out from the receiver to the R line in on the sub or can I connect the R and L outs on the receiver into one of the line ins on the sub, either right or left.
                Sorry for making a mountain out of a mole hill. I should just use two cables and forget all of this silliness. I was just thinking that the sub mixes everything to mono internally so would it matter much if I combined the R and L signal from my receiver before it got to my sub? Maybe I should just try it but I figured I would try to tap into the wealth of knowledge here in the forum first.
                Thanks everyone.
                • junior77blue
                  • 635
                  Im the same way...
                  I'm willing to bet you need to send it both R/L signals. That or use a jumper at the reciever end to send both r/l channels.
                  Either way would work.
                  From what a sales guy told me, using both the L/R inputs to the sub will only effect the output level by 3db. You will just have to tweak the knob a bit. But I'm not so certain how or why...figure i'd pass along his comments, very knowlegeable guy.
                  • Clive
                    Home Theater Glossary
                    by Clive
                    G'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
                    I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...
                    11 July 2005, 22:38 Monday
                  • BWLover
                    Rotel + Sub
                    by BWLover
                    Hello everyone! I'd like some advice on how to hook up a B&W subwoofer with a stereo pre-amp, as I have only ever done this with receivers (dedicated sub out line). I would like to use the crossover on the sub to send anything above 80hz to my B&W 683S1's. What are my options for doing this...
                    25 January 2016, 12:33 Monday
                  • RebelMan
                    Top Ten Reasons Why Subwoofers and B&W Loudspeakers Don't Mix Musically... Usually
                    by RebelMan
                    DISCLAIMER: I make some pretty bold statements in the proceeding essay. If you think you might be offended stop here. It was not my intention to offend anyone but I have some very strong feelings about this subject as it pertains to B&W loudspeakers.
                    Some people are of the mind...
                    02 June 2007, 16:38 Saturday
                  • beden1
                    Classe CAM Mono Blocks or Music Fidelity 550K Superchargers?
                    by beden1
                    I have been looking into upgrading the amps for my main 803Ds. These speakers do require some decent power.
                    I am currently using a Classe CAV-150 (6 channels X 150 watts), that I had set-up for bi-amping my front three speakers. Recently, I changed to connecting my five speakers through...
                    28 April 2008, 13:56 Monday
                  • grandsvaux
                    My local classe retailer Sigma Mono 's
                    by grandsvaux
                    As requested the pic's of the Classe Mono"s on loan from my local retailer
                    when they go back they will be replaced with my CA M-600 the rest of the gear in the pic is my set up I also use the cm1 for the rear HT
                    the speakers to the rear are Artcoustic in wall speakers a large 6X 10...
                    10 October 2016, 15:34 Monday
