Help
  • neanderthal
    • Sep 2017
    • 3
    Help
    Recently joined and got great help fixing my Cambridge audio 640c so I thought I'd try again. I have a Panasonic sa-xr15 AV amp which started showing fault code f76 and switching off. It would turn on again but only for a few mins. I disconnected everything and then reconnected. It worked faultlessly for a few days and then blew the plug fuse. I've taken lid off and nothing obvious burnt or damaged. Has anybody got any ideas if this is fixable? I have basic soldering skills. Any ideas very welcome.
    can you find out exactly what fault code f76 is?
    maybe check with the gang over at diy forum?
      • 4158
      Find and visually check the power supply board in the unit. Look for crowned (bulging) and/or leaking capacitors. Replace any bad ones you see, remembering to observe polarity and discharge the unit. Unplug and press the power switch before letting it sit for at least 8 hours (overnight is good). That's a good place to start. Hope this helps.
      • neanderthal
        • Sep 2017
        • 3
        Thanks for all the advice. Will try that and update. Cheers.
        • steffche
          Service Menu Philips
          by steffche
          Does anyone know where to get a list of fault codes for Philips plasmas? I went into teh service menu last night and noticed it had stored a fault code 027 and it pointed to being something to do with the +3v power supply or something????
          Actually I would really like more info on some...
          16 September 2004, 18:52 Thursday
          Da Vinci Code news
          by Andrew Pratt
          Tautou to play opposite Hanks
          French actress Audrey Tautou poses for photographers at the German premiere of "Mathilde - a great love" in front of the entrance of a cinema in Hamburg, northern Germany, Thursday. (AP Photo/Christof Stache)...
          22 January 2005, 19:35 Saturday
        • JohnSC
          Firmware Code
          by JohnSC
          Does anyone know what software development tool is used to code the firmware for the RSP1066 etc. Wouldn't it be great if we could code our own fixes, improvements etc., especially when us die hards keep the unit for many years and Rotel have moved on to their latest and greatest and we would like to...
          08 September 2002, 01:19 Sunday
        • AGS
          IR Code help...please!
          by AGS
          So we recently got Comcasts HD DVR and a new plasma...very nice. But let's face it the set up is a bit hard for the family and others to use...so I was thinking why not program the cable box (Motorola DCT6412) remote for basic tv use. That way when my mom is here babysitting for us she can turn on...
          22 January 2006, 16:25 Sunday
        • nmit5903
          Region code error on RDV 1050 E
          by nmit5903
          I have had region code error problems since buying an RDV 1050 E 2 years ago. As time passes the equipment seems able to read less and less of the DVD's that we buy. Can anyone help please in to reprogram the equipment to read any region code DVD.
          09 February 2008, 02:19 Saturday
