Tools to help tweak your computer for minimum latency.
    I thought I'd share a few of the tools that I've used to get my computer to respond the best for when playing audio. It all seems to help... so why not take the time and see how your computer is doing and if you're unable to set your buffers on the devices to minimum... these should help!
    First thing I use is DPC Latency Monitor.
    It's very easy to use, download it, place it wherever you want to run it (just a .exe file) and watch the latency. Anything that stays in the green is good. The lower in the green the better of course, but you should be able to run this program the whole time will playing a track and it should never jump above 500... infact when playing mine hovers around 150 - 300. That's on a Intel Core 2 Duo @ 2.4GHz with 8GB of ram.
    If you get some blips above 500 and want to figure out what is possible doing it then you need to grab LatencyMon.
    When you run this program, click on the Drivers button and then click the green arrow. After a few seconds it'll start recording what's taking the processors time. Let it run for about a minute or so to get a good idea what's taking the processors time. My guess is if you have anything that's taking even close to 1ms of time, that's you problem. Here's a shot of my computer to give you an idea. You'll see that my TCP/IP is taking the most time as it's streaming the music. So that make sense.
    If I turn on my battery to charge it (well show the icon as well) it'll cause massive latency. So I've disabled the "Microsoft ACPI-Compliant Control Method Battery." Fixed it right up. Now of course if I pull the plug and use the battery, I then have no idea when the battery will die and it will run it completely out. So you have to be careful with that one. Another one is the NIC drivers will often cause problems, so make sure you have the latest drivers installed.
    One of the greatest helps is to edit your power options and set windows to High Performance over Balanced. When you do this a LOT of the latency issues go away. So I'd start here first (even though I put it at the end).
    These are great tools!
    I have them on my server & anytime I've had issues with drop-out or pops & clicks, these have always pointed out the culprit.
    Then Dan fixes it for me :W
    • Kevin P
      A "green" file/media server and VM box (now called the Phantom Quattro)
      by Kevin P
      I'm tossing around some ideas for building a file server/development/VM (virtualbox) system. The criteria I'm using for now is:
      1. As green as possible, since it'll be running 24/7
      2. Enough performance for running OSes under Virtualbox, so that this system can eventually replace...
      12 February 2009, 13:27 Thursday
    • mike88nf
      Computer/XBox/TV speaker setup...
      by mike88nf
      Hey guys, first post here so not sure if this is where I should post this, just let me know if its the wrong forum.
      Ok, my current setup is a 32" LCD HDTV with my computer and my XBox360 hooked up to it.
      I have the hard drive hooked up through the VGA input and the...
      07 December 2005, 22:25 Wednesday
    • cobbpa
      My Computer's Value?
      by cobbpa
      So I purchased this computer less than a year 1/2 ago as a workhorse laptop to replace my fried desktop. I take it out & about sometimes, but at ~10 pounds, I can't carry it to class everyday. I never wanted to before, but now that option is starting to be more valuable. I searched a little online...
      20 November 2006, 13:31 Monday
    • JoshK
      DIY Battery Power
      by JoshK
      OK, I'll bite.
      Interested to know Jon's take on battery power in the DIY realm. My own application involves power UcD400 modules off of two APS battery packs ($25/ea on surplus market) which have 4 12V7ah batteries in each and a battery charger. Together...
      23 August 2005, 11:06 Tuesday
    • kpodolski
      Battery powered phono pre-amp???
      by kpodolski
      I have a Cambridge 640P and had some questions regarding powering it via a battery instead of the wall wart. The pre-amp requires 12v .05a. Before wasting time and money building a battery pack I used my 12v motorcycle battery. When I power the unit up with the battery the power indicator lamp lights...
      31 January 2009, 23:15 Saturday
