Connection between Receiver and external pre-amp
  • alexandrefontes
    • Sep 2013
    • 4
    Hi, i need some help.
    In order to get Home Cinema sound i´m trying to connect my receiver (Rotel RSX-1057) to my stereo set up (Audiolab 8200 CDQ (Pre-amp)/Audiolab 8200 P (Power)). On the Rotel i´m using the Pre-out (Front Left and Front Right), and on the Audiolab Pre-amp i´m using the Video Input with the Home Theather Mode enabled, but the only signal that i get is from the central speaker, surround speakers and the subwoofer.
    Oh, The Audiolab´s are driving the front speakers, obviously. Surely i´m missing something, please someone help.
    Regards.
  • madmac
    • Aug 2010
    • 3122
    The Rotel can do all the amplification for your home theater??. Why are you using the other equipment for this purpose?. Is it because your Audiolab has better power and performance?.
    Are you trying to use the Audiolab to drive only for right and left speakers?.
    Dan Madden :T
    • madmac
      • Aug 2010
      • 3122
      Dan Madden :T
      • Kevin D
        • 4601
        I could find anything in the CDQ manual about home theater mode. I'm assuming that puts the CDQ to the video input with no volume control? Make sure you are using the L/R pre-OUTS on the Rotel, not the L/R multi-inputs (guilty before here)
        Kevin D.
        • alexandrefontes
          • Sep 2013
          • 4
          Kevin D.
          Hi Kevin.
          Yes the CDQ is in the Video input with the Home Theater Option enabled, with fixed gain/volume control (it has a trimming option).
          I´m also using the pre-outs FL/FR on the Rotel, i don´t know what to do next...
          • alexandrefontes
            • Sep 2013
            • 4
            Hi madmac.
            I´m using the audiolab´s for stereo use, because they are far better for that than the Rotel.
            Like i said in the initial post, The Audiolab´s are driving (only) the front speakers.
            Because the Rotel has pre-outs, and the Audiolab 8200 CDQ has a Home Theather mode, i was trying to "put them together".
            I´m only getting signal from the central speaker, surround speakers and subwoofer.
            :cry:
            • Kevin D
              • 4601
              Can you plug the front outputs from the Rotel directly into the 8200 to rule out the outputs?
              Kevin D.
              • alexandrefontes
                • Sep 2013
                • 4
                You mean, connect directly the Rotel outputs to the power (8200P)?
                Kevin D.
                • knifeinthesink
                  dynaco tube or audiolab 8000a
                  by knifeinthesink
                  Fortune has smiled on me and I found an audiolab 8000a for less the $300, and a dynaco (dont know the model) tube amp with a seperate preamp for $250.
                  I used to have an audiolab and I really loved it, but I've been wanting to try a vintage tube amp for a long time.
                  Either...
                  15 August 2006, 23:55 Tuesday
                • peterpan
                  OT: Preamp suggestions
                  by peterpan
                  I need a preamp to use with a ROKSAN PWR amp. No esoterica plse. Thinking on the lines of 1: AUDIOLAB 8000Q 2: AUDIO ANALOGUE BELLINI 3; croft vitale, am I on the right path?
                  30 October 2006, 08:50 Monday
                • Clive
                  Home Theater Glossary
                  by Clive
                  G'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
                  I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...
                  11 July 2005, 22:38 Monday
                • ti33er
                  804S with Audiolab 8000M/P amplifiers
                  by ti33er
                  Hello all
                  It's been a very long time since I have been on this forum!
                  My flatmate should be getting a pair 804S tomorrow and just wondering if anyone has tried 804S with Audiolab 8000M (monobloc) or 8000P (stereo) amplifiers?
                  I have a single 8000M and an...
                  19 June 2008, 08:25 Thursday
                • Lim
                  Lexicon MC1 + Audiolab Amps
                  by Lim
                  I am new here. I have read some very knowledgeable posters here and thought this is where I may get some help.
                  I recently bought a Lexicon MC1, then I found an Audiolab 8000M and three units of 8000P. My question is would these Amps work well with the MC1 and how should the set up be,...
                  16 January 2009, 03:24 Friday
