Power Issues? reading diff. volts
  • crytklmass
    • 145
    I receive 100amp service to my home. My power conditioner NEVER stays at a constant voltage. It varies between 122.1 - 124.4 The home was built in the 1950 with original service to home. (3 individual power cables coming from the pole to the home). It should read 120 correct?
    Before using a power conditioner I received a ground feedback hum (coming from the cable t.v.) still happened even after installing a cable tv ground from local electronic store. $5.00. The power conditioner filtered out the noise. I don't understand why the voltage changes constantly. throughout the day it reads a different voltage.
    Power Conditioner is Monster 2550.
    f.y.i. The house is mixed with both grounded and ungrounded outlets. Only the kitchen and bathroom were grounded. There are grounded outlets in the home, but they are not really grounded (reading a hot/neutral reverse via outlet tester). Not sure if this is causing problems. Electrician will be arriving in 2 weeks to hookup hot tub. Anything I should have him check while he's here?
    BOB
  • Glen B
    • 1106
    YOU HAVE NO PROBLEM. The voltage range you're seeing is perfectly normal and within the utility company's tolerance. Voltage does not remain at a rock solid 120V but fluctuates constantly throughout the day as your neighbors and other users of electric power in your area turn their devices on and off. Wait until summer comes around and all the air conditioners go into use. Voltage is likely to drop a good bit below the 122V lower limit you're now seeing.
    The electrician needs to correct the reversed hot/neutral wiring. The neutral is normally grounded at the electrical panel. Some equipment, like lamps for example, with a polarized plug (one blade wider than the other) often have the neutral side connected to its metal housing. If you plug such a device into an outlet where the wiring is reversed, and the neutral side will be connected to the hot side of the electrical supply, energizing the metal housing and posing an electrocution hazard.
    See wall voltage thread here:
    http://audiokarma.org/forums/showthread.php?t=179643
    • BWLover
      Power Conditioner/Voltage Regulator
      by BWLover
      Hi there everyone! I recently had my stuff moved out of storage from another province to the province I moved to three years ago, it's so nice to have my stereo back. I've got a quick question about my power conditioner. At my old place the power coming in was pretty stable at 120V, every once in a...
      10 July 2016, 10:38 Sunday
    • ht_addict
      Tripp Lite LCR240 input needed as power line conditioner
      by ht_addict
      Just curious if anyone could give some feedback on the Tripp Lite LCR2400. It seems to do the same as the Monster AVS2000 but at a fraction of the cost.($375CDN) definitely has the power output to handle a hungry HT. Here's a link.
      DESCRIPTION
      18 October 2003, 09:32 Saturday
    • YeeDude
      RLC 900/line conditioner questions
      by YeeDude
      I'm am looking to buy either an RSX 1055 or RSP 1066 and a RMB 1075 within the next two months and noticed the RLC 900 on Rotel's website while looking around.
      Let's skip past the "do line conditioners make a difference" question for now and assume (for argument's sake) that...
      30 December 2002, 16:43 Monday
    • misterdoggy
      Can you over filter your line with conditioners etc
      by misterdoggy
      I think this is still on topic as it has to do with the end sound coming out of our speakers.
      Question is: I have heard from some experts that some line conditioners can over filter the electricity causing a montone feeling to your system.
      Now I have a problem in my town...
      23 June 2006, 05:13 Friday
    • at_sunset_blvd
      Line Conditioner to a Regulator?
      by at_sunset_blvd
      Guys is it ok we plug our line conditioner to a voltage regulator or should it be the other way around? Problem is I dont have an extra outlet anymore, it's all occupied.
      11 February 2007, 17:43 Sunday
